Home > In Car Electronics > Evoque Torch |
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 408 |
It's a Discovery one. Not sure what the actual difference is?
£90 inc VAT, not sure about postage. |
29th Dec 2015 5:16pm |
chrispy Member Since: 13 Mar 2015 Location: Gwent Posts: 347 |
I've already pm'd him about this. I'm in for a group buy as my wife's 90 is screaming out for one of these, although where to fit in a pre Puma?
29th Dec 2015 5:17pm |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
^ how about front slant bit of cubby? My 109 thread
my youtube channel |
29th Dec 2015 5:23pm |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen Posts: 631 |
will set up a group buy tomorrow https://www.facebook.com/duckworthparts
Send a paypal payment direct using this link www.paypal.me/duckworthparts www.duckworthparts.co.uk My Direct Line: 01673 849873 Email: danroberts@duckworthlandrover.co.uk Supplier of Genuine Land Rover & Jaguar Parts For All Models Can also supply OEM & Aftermarket parts |
29th Dec 2015 5:24pm |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 |
I believe someone mentioned the only difference is to do with the size/shape of the mounting unit... Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
29th Dec 2015 5:38pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Wow,can't imagine the number of PROPER, QUALITY flashlights I can buy for £90!!!Shame it doesn't have "Landrover" stamped on it tho !! Pov.spec,ftw. 2006, 110,TD5.
29th Dec 2015 6:47pm |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2754 |
Rechargeable with dock?
Only small rechargeable ones I found had separate cable with wall or 12v plug - not ideal. I think £90 odd is reasonably good value considering how quality & smart it looks. Each to their own though. Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
29th Dec 2015 8:35pm |
Group Buy is up; http://www.defender2.net/forum/topic42703.html
30th Dec 2015 11:24am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20348 |
Smartwater it too, just in case it goes walkies.
30th Dec 2015 12:59pm |
Now that the group buy is going ahead, would someone that's feeling brave document the fitting process in the puma dash?
1st Jan 2016 7:25pm |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 |
As soon as I receive mine, hopefully by Wednesday, I´ll let you know (with pictures) what its about.
Stephen 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MT´s, Recaro CS´s, anorak, wellingtons |
1st Jan 2016 7:35pm |
How is the fitting going?
Im waiting for a Dremel to start hacking at my dash... |
13th Feb 2016 5:35pm |
So I took the plunge..... and cut a massive hole in my dash!!!
I masked off the panel where the torch would be installed and cut using the Dremel; Click image to enlarge I tried to block the little shavings of plastic from going down inside the dash but it was useless. In the end I just used the hover after to clean up the best I could. Next I sanded down the hole and made it all look neat, I also had to cut back the reinforcement behind the hole so the new metal reinforcing bracket would fit flush to the back of the dash; Click image to enlarge I glued in the new metal reinforcing bracket; Click image to enlarge Installed the torch; Click image to enlarge Wired it up using the supplied loom for now. The green charging light is flashing so it all seems to be working. |
7th Apr 2016 5:40pm |
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 |
Looks good, still need to do mine
7th Apr 2016 5:49pm |
