![]() | Home > Puma (Tdci) > Dashboard light |
stanley Member Since: 18 Sep 2009 Location: Dorset /hampshire Posts: 1033 ![]() ![]() ![]() |
redline Member Since: 28 Jun 2015 Location: Mountains and Lakes Posts: 221 ![]() ![]() |
Thanks Stanley!
Hmmm... The light doesn't come on when I engage low range, so I assume that the light/switch has a problem... Whilst we're on the subject of dumb questions, does anyone know what this switch does? Its on the right hand side of the steering column (LHD vehicle). Again, nothing in the manuals. ![]() Click image to enlarge |
Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 288 ![]() ![]() ![]() |
Low range light is not hooked up on a Defender.
Guess your other switch would be for an auxiliary light or aftermarket accessory.
The dash was shared with a Disco 3 which does light something up when you're in low range, the Defender doesn't. It has a diff lock light but that's it. I'm surprised you've actually got a blank there tbh, I'd never noticed it in mine.
As for the switch... that's not a standard one but looks similar to the dealer fit worklight switch. Have you got some accessories that don't work? |
Guys - thanks for the clarifications!
I can only see the Lo-Range symbol if I peer at it closely with a torch. It has never lit ... for obvious reasons now ![]() Regarding the switch: It could have been for a work light, previously removed. I have not checked the wiring yet. It looks a factory fit, or at least a lot better than some of the strange wiring/switches added by the previous owner! |
That's a switch for rear work light
http://accessories.landrover.com/gb/en/def...worklight/ This light as I have the same |
Crikey.... £254.00!!! I wish it was still on there! The previous owner must have removed it....
If you want I'll sell you one for a lot less than that
![]() I've got three. I hope yours is wired better than mine was if you think that's good wiring, mine were horrendously bad. I'd have been embarrassed to do something that badly. Edit: I think I've found some news about the new Defender, it's slightly longer! ![]() Defender 111 ![]() |
