Home > Group Buys > Nolden LED Headlights
Sign Up
(23)
(3)
(2)
User Registered Confirmed
Lorryman10025th Oct 2014 6:22pm
captain slow26th Oct 2014 12:54pm
Windowlicker27th Oct 2014 8:01pm
L90Andy28th Oct 2014 8:02am
mark_d31st Oct 2014 7:25pm
Hufflepuff2nd Nov 2014 11:37pm
LR Sam10th Nov 2014 1:42pm
josefk15th Nov 2014 8:23am
carrotbay19th Nov 2014 11:03pm
JAY BOY10th Dec 2014 6:34pm
bob neville16th Dec 2014 7:40pm
airpusher24th Dec 2014 1:22pm
LittleFoot2nd Jan 2015 6:23pm
jomara5th Feb 2015 12:26am
ttman33323rd Oct 2015 6:25pm
Merlin27th Oct 2015 6:46pm
Johnb11th Nov 2015 12:47pm
Jonh18th Nov 2015 9:18pm
Vanderbult15th Dec 2015 4:36am
Alun10th Feb 2016 8:50pm
N16kct22nd Feb 2016 8:25am
Shadow7710th May 2022 10:36am
110NTK2nd Jun 2022 9:21am
Laurie25th Oct 2014 9:05pm
LR90XS201126th Oct 2014 5:32am
ARC9931st Oct 2014 5:23pm
defender_uk23rd Dec 2014 6:12pm
TD5Nick10th Mar 2015 9:43pm
Page 10 of 11 <123 ... 91011>
Pickles
Thanks Brendan, but on say '13 & onwards Puma, they did not have built in side lights did they?
Pickles.
Post #506340 20th Feb 2016 8:11am
ericvv
All Defenders in principle are like yours Pickles, so with separate side lights. Only those with SVX, ICE, Fire, Raw, etc. style fronts have the sidelights integrated in the 7" main headlamp, and have the turn signal in the place of where your sidelight is located, and have at the lower outside of the lights cluster a 90mm aux high beam lamp.
Eric
Probably overkill, but here are two pictures showing the two set ups.
Standard front with separate position lights on the upper outside.
SVX (here a local ICE) front set up with integrated position lights, and with turnsignal on the upper outside and the 90mm aux high beam driving lamps on the bottom outsides.
Seems you have some interest to upgrade your standard "candles" to LED? Each to his own of course, but my personal preference with the standard set up like yours would be to not connect the sidelights of the new LED headlamps (if you buy a set that comes with a integrated sidelight function), but I would replace your standard filament bulb yellowish sidelights by a good quality crispy white set of standard model LED sidelights. Plenty of posts about that here. If you do that, you keep the standard function and look (I personally think two sets of sidelights, and then different shaped, looks odd), but hey, each to their own of course, and you will have about the same crispy white colour in both your new LED headlamps, and in your new original looking LED sidelights.
Now, the (cheaper) alternative for you to get a good light upgrade is to replace your standard fishbowls with the WIPAC clear cristal lamps, plus better quality halogen bulbs (even available from your LR dealer themselves), plus the upgraded Dutch Landreiziger headlights loom which will steer the full 14.4V to your lamps, and which will also avoid that your light switch one day will melt. And then you can leave your filament sidelights as is too. Thumbs Up
Leaving your sidelights, turn signals front and back, as well as your tail/stop lights just original is certainly no problem for you even if they are not perfectly water proof Rolling Eyes , given that you get much more sun than rain down under. Cool
If you go for LED headlights, below is a picture of the Trucklite standard front set up (borrowed from TomekW) with the standard sidelights and turn signals also replaced by a LED version. I believe in Aussie the Trucklites are the most widespread and readily available, yes?
Eric
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #506350 20th Feb 2016 9:18am
Pickles
Thanks eric, so I'd want the items without the integrated "side lights"?
Thanks, Pickles.
Post #506484 20th Feb 2016 8:09pm
leeds
Your choices for Noldens, Pickles are:
1) Clear chrome Noldens without position lights. Simple plug and play with the H4 connector
2) Clear chrome, dark chrome or matt black with position lights
If you want a coloured Nolden it will have to be with position lights
However you have choices
a) Do not connect the position lights up. The position lights plug comes with a sealed insert which you can leave in
b) Connect the position lights into the existing side light circuits. Having two sets of position/parking/side lights is legal.
HTH
Brendan
Post #506549 20th Feb 2016 10:08pm
Vanderbult
Netherlands 2011 Defender 90 Puma 2.4 SW Santorini Black
Hi Guys!
So im fairly new to this forum and this is the first groupbuy i've registered for.
I would really like to get a pair of Nolden LED Hedlights, the chrome ones but i don't really understand how this group buy works.
Would someone be so kind to explain this to me?
I found a guy in the Netherlands (where im from) who can deliver a set with the hight adjusters and mounting trim for € 950,-
but i already have the hight adjusters on my 90 so i only need the Headlights by it's self.
So... HOW DO I GET THEM?
thanks a lot guys!
GR, Rick
Post #520218 2nd Apr 2016 9:23am
leeds
Hi Rick,
Group buys are in theory relatively simple. A group buy is just as name says a group of people agreeing to buy the same item at the same time at a reduced price. The trader can offer a reduced price as they may be able to negotiate a better price with their supplier.
Now in the case of Noldens our agreement is that we stick to the right hand drive, left hand traffic, I.e. UK type traffic. We can not help our European friends directly. May I suggest you contact Nakatanenga in Germany for European style Noldens? They are site sponsors as well and have a very large range of lights.
Hope that helps
Brendan
Post #520224 2nd Apr 2016 9:48am
Vanderbult
Oke this is clear to me now, thanks!
so what is the difference between UK and european lights? is it that the (for me, here in the netherlands) light flair raises up on the right side of the road to illuminate more of the area next to the road? or do these light have the exact same light flair and is it just some UK/Europe certificate for insurance purposes or something?
Thanks a lot!
Post #520239 2nd Apr 2016 10:31am
Cupboard
We drive on the other side of the road, so our kick up is on the other side Thumbs Up
They're all built to the same standard, on that note you're looking for the E marking which Noldens and other good headlights have, cheaper ones don't.
Post #520303 2nd Apr 2016 3:57pm
forest172
2013 Defender 90 Puma 2.2 SW Santorini Black
Are these plug and play? 2015 90SW Heritage MY16, 2016 90SW XS MY16 (123rd b4 the last build) & RRS HSE MY15
Post #526270 23rd Apr 2016 7:19pm
leeds
Basically plug and play. Just screws drivers to undo indicator, side light etc.
A bit of string is useful, tied to sidelight, indicator wiring loom. Makes them easier to fish out if they go into the wing, especially if you have fat fingers!
As long as you do not touch the adjustment screws extremely straight forward.
Brendan
Post #526298 23rd Apr 2016 8:20pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Are there any offers coming up on these soon? 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #870813 1st Dec 2020 8:41pm
SJM2018
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Aintree Green
I’m interested in a set too 2011 CSW XS 90
Post #873689 18th Dec 2020 10:38pm
Zirmbach
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Santorini Black
Digging up an old thread but if anyone has them I guess it's those who did group buy! Looking for chrome RHD 1st Gen pair if anyone wants to shift them...
Post #950740 27th Apr 2022 12:40pm
110NTK
Well that’s 3 of us… surely more lurkers…. Don’t wanna risk the eBay ones…
Post #950900 28th Apr 2022 6:59pm
Zirmbach
Every seller I’ve contacted has only LHD or gen 2
Post #950910 28th Apr 2022 7:43pm
