![]() | Home > Td5 > Newbie help |
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 ![]() ![]() |
I thought the port was under the passenger seat by the battery on the Td5? Seem to recall my mate's 90 has an OBDII port there?
Correction: Look by the front left corner of the cubby box/tray between the front seats, next to the battery box and partly obscured by the passenger seat squab. ![]() 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
daviec1 Member Since: 30 Nov 2010 Location: Ayrshire Posts: 246 ![]() ![]() ![]() |
Cheers - 1 OBDII port located - now off to order the Scanguage
Perfect example of the benefits if this forum. |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 588 ![]() ![]() ![]() |
Make sure a scangauge will work with the TD5. It has some not normal protocol from what I believe.
Hopefully someone with more knowledge will be along shortly. Steve |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
Scangauge wil NOT work with the TD5.
The only real alternatives for DIY use is a Nanocom or a Hawkeye, with in my personal opinion the Nanocom is far superior. Pete. |
changill Member Since: 13 Dec 2008 Location: North West - Preston/Lancaster Posts: 27 ![]() ![]() ![]() |
I don't think the Scanguage works on TD5's..........Let us know if you manage to get it working? Only Alcohol Can Save me Now Nanocom Available in the North West |
Cancelled order and went for Nanocom Evolution, which should be here anyday.
