Home > Td5 > Newbie help |
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 |
I thought the port was under the passenger seat by the battery on the Td5? Seem to recall my mate's 90 has an OBDII port there?
Correction: Look by the front left corner of the cubby box/tray between the front seats, next to the battery box and partly obscured by the passenger seat squab. 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
29th Dec 2010 3:31pm |
daviec1 Member Since: 30 Nov 2010 Location: Ayrshire Posts: 246 |
Cheers - 1 OBDII port located - now off to order the Scanguage
Perfect example of the benefits if this forum. |
29th Dec 2010 4:06pm |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 587 |
Make sure a scangauge will work with the TD5. It has some not normal protocol from what I believe.
Hopefully someone with more knowledge will be along shortly. Steve |
29th Dec 2010 4:20pm |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
Scangauge wil NOT work with the TD5.
The only real alternatives for DIY use is a Nanocom or a Hawkeye, with in my personal opinion the Nanocom is far superior. Pete. |
29th Dec 2010 4:43pm |
changill Member Since: 13 Dec 2008 Location: North West - Preston/Lancaster Posts: 27 |
I don't think the Scanguage works on TD5's..........Let us know if you manage to get it working? Only Alcohol Can Save me Now Nanocom Available in the North West |
8th Jan 2011 9:08pm |
Cancelled order and went for Nanocom Evolution, which should be here anyday.
8th Jan 2011 10:08pm |
