Home > Technical > Clunk, Bang, Loss of drive, one angry geordie pushing....
DavidS
United Kingdom 2011 Defender 110 Puma 2.4 USW Stornoway Grey
Decided I am going to work bank holidays in future, it must be more fun than pushing the f@cking thing to safety!
Anyway, pulling away from a junction, got a clunk as I engaged the clutch, got half way into the traffic and got a loud bang and total loss of drive.
What are my likely causes (clutch, shaft?), and roughly how much should I expect?
110 2.4 2011.
Thanks in advance
David 2 LandRovers, and counting!
Post #518656 28th Mar 2016 9:42pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
Could be anything, most obvious is to make sure the transfer box hasn't jumped into neutral...
Will it drive with the diff lock engaged ? http://www.yorkshireoffroadclub.net/
Post #518657 28th Mar 2016 9:45pm
DavidS
Transfer box is engaged, didn't try the diff lock, but couldn't engage any gear only got grinding whirring noise.
It got recovered on a flatbed.
Is that what happens when the output shaft gives up?
It has had a clutch 20k miles ago. 2 LandRovers, and counting!
Post #518660 28th Mar 2016 9:50pm
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
Oh no not another one! Adapter shaft spline failure between gearbox and transfer box, well known problem I'm afraid.
Post #518661 28th Mar 2016 9:50pm
If it drives with difflock engaged, then most likely halfshaft/drive flange spline failure. If it doesn't, most likely the gearbox output adaptor shaft.
Post #518663 28th Mar 2016 9:52pm
DavidS
Scoobeenut, what is required and roughly how much? 2 LandRovers, and counting!
Post #518664 28th Mar 2016 9:52pm
Scoobeenut
Had to have mine taken back to dealers on a flatbed too. Adapter shaft spline failure loss of drive in any gear but engine running fine. Total bill at dealers was about £600 but after many phone calls JLR made a good will payment of 50%
Have a read of this thread http://www.defender2.net/forum/topic36916.html
Post #518666 28th Mar 2016 9:58pm
DavidS
Ok thanks for that.
I will find out in the next couple of days and let you know. 2 LandRovers, and counting!
Post #518670 28th Mar 2016 10:02pm
DavidS
So it has been confirmed to be the output shaft.
Getting repaired today. 2 LandRovers, and counting!
Post #519192 30th Mar 2016 11:23am
Happyoldgit
Make sure they grease the splines. Steve.
http://forums.lr4x4.com
Post #519195 30th Mar 2016 11:26am
DavidS
Yes all greased. To be fair it has never been so smooth, which is quite annoying. 2 LandRovers, and counting!
Post #519266 30th Mar 2016 5:47pm
Pickles
"Grinding whirring Noise",..Yeah, exactly the noise we got when Gracie's output shaft failed a few weeks ago,..she ended up on a flatbed too!
All fixed now though, Pickles.
Post #519396 30th Mar 2016 9:19pm
