Home > Tdi > 200 TDI Fuel Injection pump |
Tompoole Member Since: 05 Jun 2011 Location: Bucks Posts: 827 |
It's going to be unlikely the injection pump that's goosed
I would check fuel lines ok then replace lift pump with new one , lift pump Diaphragm prob knackered and pop new solenoid if that's sticking. There was a trend for dealers to swap lift pump and injection pump when only lift pump Was worn , those injection pumps are good for at least 500,000 mile before you need to touch it. My guess it you haven't got fuel at injector then stop solenoid Have fun be happy |
28th Mar 2016 1:06pm |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
Check the return pipe unions are tight on the injectors otherwise the pump pulls in air from them and gives you starting issues. Pull the plunger out of the stop solenoid and check for any signs of metal swarf stuck to it, that's a sure sign of pump issues. The earlier VE used on the 200 are much longer lived than the 300 version that is prone to shaft and cam ring problems but I have seen problems with the 200s so don't discount it.
28th Mar 2016 8:51pm |
