Home > Tdi > Urgeant help with PAS whine before i make fire |
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 |
Hello, lots of different options on pipes. Depends on model and engine. But try getting the front wheels off the ground and turning steering wheel full lock to full lock a few times. It worked for me. Good luck.
27th Mar 2016 12:09pm |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 809 |
Are you absolutely sure the sound is coming from the steering system? Have you tried starting the engine with the drive belt removed? While the belt is off give the other ancillaries a spin by hand as it could be something else that is making the noise, are the water pump and alternator turning smoothly?
6th Apr 2016 8:57am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8029 |
yours a 300tdi?
there was a recal on them to change a pipe which resonated causing noise issues (97 era that was) Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
6th Apr 2016 5:24pm |
