Upon removing the front prop...
This happened...
Id say from the amount that came out, the entire space between the the two flanges was full of gearbag oil.
I'm going to take a stab at guessing this isn't normal? (Though probably common)
Whats the likely cause/solution?
I'm going to have a look at the rear now.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated
25th Mar 2016 1:37pm
Retroanaconda
The nut holding the drive flange on has a seal under its washer which prevents oil migrating up the threads. Perhaps this has failed or not been installed.
25th Mar 2016 1:45pm
Cetane
The back was leaking also. Im going to drop the box for a clutch change. Will check things over then.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
