![]() | Home > Maintenance & Modifications > converting a 110 sw into a double cab what's needed? |
hoagy Member Since: 26 Aug 2015 Location: lincolnshire Posts: 5 ![]() ![]() ![]() |
Hi I'm in middle of converting my double cab into a SW, just collecting parts so far
George G Member Since: 02 Feb 2015 Location: Derbyshire Posts: 21 ![]() ![]() |
From what I remember:
*Roof *Rear pickup surround *Rear window *Pick up 1/4 windows *Tub capping strips (they are different to the SW ones) *Rear bulkhead (can be made with some metal work skills) *Rear pick up door plus hinges, lanyard and locks/stops *Headlining *Maybe different brackets for rear seats Im sure there is some more though but cant think what. ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17718 ![]() ![]() ![]() |
You'll need the roof, cab rear panel, rear tub, tailgate, rear seat box, rear seat mountings, and rear seats if you want to make it look "factory". If you dont mind it looking home-made you can probably adapt some of your existing panels.
The best bet is to find someone converting the other way and do a swap pf parts. |
