Home > Technical > Springs and Shock absorbers Defender 90 300Tdi |
Alex1976 Member Since: 23 Jan 2013 Location: Buckingham Posts: 596 |
I am running standard front springs on both the front and rear with Terrafirma dampers. The front springs on the rear give a much softer smoother ride. I have also got red polybush all round.
I find this set up spot on and cost a fraction of the 'special' suspension packages out there. |
24th Mar 2016 8:11am |
Seabreeze Member Since: 23 Mar 2016 Location: Suffolk Posts: 47 |
OK, many thanks for that. I am looking also looking at standard Land Rover springs and some form of alternative shocks. Terrafirma have been suggested as have Extreme 4x4's own, oil filled shocks (not gas).
30th Mar 2016 9:40am |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 819 |
I have run Boge Shocks with the Std Land rover Springs as a cost effective option, ride is not bad and prefer them over the TF ones as IMHO the TF ones are a little hard on an unloaded 90.
Some also find the Bilsteins a tad hard off road and are usually considered as more of an on road or expedition upgrade where towing and heavy loads are involved. But if I was spending money the adjustable Koni Shox would be my first choice. N. |
30th Mar 2016 4:47pm |
Many thanks, I will look into Koni. I spoke with the Bilstein people, they told me that they had nothing that would fit with a Defender 300 Tdi!
30th Mar 2016 8:36pm |
