![]() | Home > In Car Electronics > Work light - illuminated switch? |
Bug Member Since: 03 Mar 2016 Location: Hayling Island Posts: 19 ![]() ![]() ![]() |
I've got a main dealer fitted work light but the switch on the dash is not illuminated and I keep leaving it on when I'm driving. I want to fit an illuminated switch but the I can't get the light to illuminate. My wiring is slightly different to the instructions shown at http://topix.landrover.jlrext.com/topix/co...oupId=1662 in that I've got black and red wires at the switch. This instruction also shows the black and red wires being spliced together at the lamp. Can anyone draw this as a simple wiring diagram, and explain how I can wire an illuminated switch. Many thanks.
Swac3 Member Since: 21 Feb 2015 Location: Aberdeen Posts: 363 ![]() |
Not if its switched earth which could explain your multi meter findings.
Cant see the diagram you posted sadly, it doesn't work for me. You 'could' take the black wire off and connect it to the switch light earth pin, then bridge the switch light input to the now empty pin you just took the black wire off. Not elegant as you're now running the work lamp or relay and the switch lamp in series but the simplest functional way round it. 3 Landrovers |
Why not just use the switch on the back of the lamp?
dave18 Member Since: 11 Jul 2015 Location: Gorleston, Great Yarmouth Posts: 497 ![]() ![]() ![]() |
Take it back you paid for them to fit it then it should be fitted correctly and legally unless I've missed something
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 ![]() ![]() ![]() |
You can use too the switch YUG000540LNF for Front Fog Lamp
![]() Click image to enlarge http://www.defender2.net/forum/post6360.html#6360 Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
