Home > In Car Electronics > Work light - illuminated switch?
Bug
I've got a main dealer fitted work light but the switch on the dash is not illuminated and I keep leaving it on when I'm driving. I want to fit an illuminated switch but the I can't get the light to illuminate. My wiring is slightly different to the instructions shown at http://topix.landrover.jlrext.com/topix/co...oupId=1662 in that I've got black and red wires at the switch. This instruction also shows the black and red wires being spliced together at the lamp. Can anyone draw this as a simple wiring diagram, and explain how I can wire an illuminated switch. Many thanks.
Post #517050 23rd Mar 2016 2:20pm
Bug
A bit more info. When the switch on the dash is OFF, there is 12V on the red cable at the switch relative to earth, and 0V on the black cable. When I switch the light ON, both drop to 0V. This explains why the illuminated switch doesn't work, but I would expect both to be 12V. Confused!
Post #517064 23rd Mar 2016 3:27pm
Swac3
Not if its switched earth which could explain your multi meter findings.
Cant see the diagram you posted sadly, it doesn't work for me.
You 'could' take the black wire off and connect it to the switch light earth pin, then bridge the switch light input to the now empty pin you just took the black wire off.
Not elegant as you're now running the work lamp or relay and the switch lamp in series but the simplest functional way round it. 3 Landrovers
Post #517079 23rd Mar 2016 5:02pm
Why not just use the switch on the back of the lamp?
Post #517155 23rd Mar 2016 8:52pm
dave18
United Kingdom 1984 Defender 110 300 Tdi CSW Portofino Red
Take it back you paid for them to fit it then it should be fitted correctly and legally unless I've missed something
Post #517253 24th Mar 2016 6:26am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
You can use too the switch YUG000540LNF for Front Fog Lamp
http://www.defender2.net/forum/post6360.html#6360
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #517374 24th Mar 2016 12:41pm
