![]() | Home > Maintenance & Modifications > Plastic vent replacement |
AlpsLandy Member Since: 11 Jan 2012 Location: Alps Posts: 116 ![]() ![]() |
Now found a few online. If anybody has bought a particular one I would be interested on whether it fit well. Body shop broke off 4 of the five plastic 'pins' when removing it so LR original not exactly bullet proof.
Thanks 2011 Defender 90 SW 2006 Discovery 3 HSE |
Flyingfocrs Member Since: 12 Jan 2015 Location: Deepest darkest Aberdeenshire Posts: 155 ![]() ![]() ![]() |
Very common for the pins to snap off.
Like many others i have carefully drilled through the vent where the pins were and the fitted it back on with some self tappers. ![]() Click image to enlarge |
Save your money and do this:
http://www.defender2.net/forum/post231742....ake#231742 |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20613 ![]() ![]() |
KBX OR D44?
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 601 ![]() ![]() ![]() |
I have one you can have for the price of the postage if it helps.
Thanks for all the info chaps. I think I will have a go at the drill and refit suggestion - good thread link, thanks.
Appreciate the offer though Stiff1 - that was really kind of you ![]() 2006 Discovery 3 HSE |
I bort a stainless steel jobbie off ebay and painted it black (600 wet and dry and etch primer).
Also drilled out the holes a bit,to increase airflow.Previously bort a non-oem plastic grill which didn't fit at all and the holes were smaller,so went in the bin. http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...XQKLdR5BKa Pov.spec,ftw. 2006, 110,TD5. |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 672 ![]() ![]() ![]() |
I replaced mine with a Britpart one (P/N BTR6188) for about £7 from ebay.
Fitted fine and hasn't fallen off yet! Couldn't tell the difference from the original other than it had all the pins. |
