Home > Puma (Tdci) > Oil Pressure Light Continues To Flicker |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 452 |
Hi,
Can nobody help or shed any further light on this? It is only coming on at idle, at 750rpm. Clearly I am not a mechanic so any help or advice is very much appreciated. Cheers. |
23rd Mar 2016 10:32am |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
Puma engines had a recal for the oil pump and pick up pipe, have you found out if your vehicle is within the recall range and been carried out? change oil filter? is yours a 2.2 or 2.4?
The 2.2 needs a certain grade oil due to it having a DPF |
23rd Mar 2016 10:50am |
Hi,
Thank you for your reply. Its a 2.4 registered Jan 2011. It had an oil service in November. I was not aware of the recall, how will I find out if its needed or been done. Is it as simple as contacting my local dealer? I am very new to owning a Defender, so not up to speed on what to look for or how to sort stuff. Thanks again for your help, Cheers. |
23rd Mar 2016 10:54am |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
I think you will find oil pump failure didn't effect 2.4s?
I may be wrong? but if it were mine, I would be taking it out to have a look for any problems with the pump and chain. Might have a blocked strainer? 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
23rd Mar 2016 11:13am |
Thanks guys, guess I will need to get the garage to take a look.
Much appreciated. |
23rd Mar 2016 11:58am |
Check on topix (search on here) to see your vehicle details and whether there are any outstanding service actions.
23rd Mar 2016 8:27pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3633 |
2011 2.4 has not had any recalls for this type of issue,
best thing to do is fit a pressure gauge to understand what the actual pressure is and check against the manual. In the mean time it may be worth doing an oil change and when draining the old oil do it by filtering the oil coming out through a fine cloth (check for any evidence of metal contamination) also ensures the oil itself is not diluted or something causing the problem. I think my idle is slightly higher than 750 what does the manual say it should be?. will check against my scan gauge tomorrow. you certainly would not expect an issue at your low mileage with a 2.4. DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
23rd Mar 2016 9:53pm |
Mine idles at 800, indicated on my ultra gauge. but mine is a 2.2.
23rd Mar 2016 10:04pm |
Cheers all.
I will check the details. Cant get it into the garage till Wednesday next week, so I will get the oil change done and might as well get the pump out too I suppose to double check that. All help much appreciated. Cheers. |
24th Mar 2016 10:55am |
Could it just be the light itself, loose connection, bad earth, faulty bulb holder?
24th Mar 2016 11:27am |
Hi Supacat,
I did think that but as it only happens once it drops below 1000rpm I discounted it. I suppose I cannot discount anything at the moment, its really driving me mad as I am worried it is going to wreck the engine if I can't get it sorted Cheers. |
24th Mar 2016 1:12pm |
