![]() | Home > Pictures & Video > Puma defenders on modular steels |
Lucifus Member Since: 29 Jan 2016 Location: U.K. Posts: 52 ![]() ![]() |
-35 would certainly poke out. I'm running (not on a puma) 285s on a 16x7 et-25 rim and they poke. 8" with -35 would really be too far in my opinion to talk your way out of a ticket on the side of the road.
Also I've had several sets of modulars. In my experience it really doesn't take much to buckle them. My first set were out of shape after light off roading. If you've got the money for a puma then I'd find the money for some decent wheels.
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
I run a set with BFGs mud terrains for the winter.
But prefer my sawtooths with BFGs all terrains which I use in the better weather. If you look in my gallery you should find pictures of the modulars ![]() |
Christian1402 Member Since: 17 Feb 2016 Location: Cumbria Posts: 214 ![]() ![]() ![]() |
I had a feeling the -35 would be too much on the standard arches. I don't fancy putting too much strain on the wheel bearings either, so not having them quite as far out will help to some degree. I've had a set of modulars on my disco for over a year and done some quite serious off reading, they're absolutely fine? I even knocked a wheel hard off a rock and popped the tyre off the wheel and that ones still good. I can't remember where I ordered them from though unfortunately. I'm just trying to picture what modular steels would look like on this; ![]() Click image to enlarge My other option was to just get some 30mm spacers for the boosts but I'd like them painted black |
Spot on, I'll have a look now, thanks ![]() |
Arran73 Member Since: 25 Mar 2013 Location: Commugny, Switzerland Posts: 133 ![]() ![]() |
I would use the AT's in the winter and muds in the summer, 1997 Defender 90 300tdi
