![]() | Home > Technical > help fitting rev counter to td5 only 1.2 volts on pin 19 |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4801 ![]() ![]() ![]() |
I believe it is a square wave pulse so I think to measure it properly you would need an oscilloscope. 2002 90 Td5 Station Wagon
defender90_dave Member Since: 04 Mar 2016 Location: Stoke-on-Trent Posts: 6 ![]() ![]() |
Sorry Grafty99 I did not make it clear in my original post but I was measuring the signal with an ocilloscope. I have come to the conclusion that the 1.2vdc is actualy correct and that I have to use the pull up circuit mentioned elswhere on the forum to get up to a 12vdc signal as an input into the standard VDO rev counter.
Thank you for your reply though matey.http://www.defender2.net/forum/images/smiles/icon_biggrin.gif |
