![]() | Home > Puma (Tdci) > Help on changing out bulbs in center dashboard |
rtg Member Since: 25 Jun 2014 Location: UA Posts: 10 ![]() ![]() ![]() |
I replaced mine some time ago. It's a rather simple job:
Remove center console (I used a flat screw driver but something like this might work better if you want to avoid scratches). After you "pop" the center console you have to disconnect the switches. I removed the switches from the front panel and reconnected them one-by-one to their respective plugs so I know what goes where. Looks something like this: ![]() Click image to enlarge Replace lights, reassemble. I used LR spare lights from my local dealer. Since some lights died on me over the last two years I'm planning to replace them all with LEDs.[/list] |
expatRob Member Since: 24 Feb 2015 Location: Frankfurt Posts: 58 ![]() ![]() ![]() |
rtg, great info thanks. I think I will go LED from the start them. Great tip on the switches to keep things in their proper place. I will use that.
Just remember if it starts looking like this
![]() Click image to enlarge you removed too much ![]() |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 ![]() ![]() ![]() |
http://www.defender2.net/forum/topic16996.html
![]() Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4739 ![]() ![]() |
The only thing I couldn't figure out is how to disconnect the clock. I managed it with the centre dash still connected to the clock. Any instructions on how to disconnect the clock.
P.S. You will need the correcty keys to remove the stereo. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
My clock came out pretty easily on Friday!
There's a plug that just disconnects. Might have to prod it with a small screwdriver but I didn't spend much effort so I can't really remember. |
Thank you. That's been filed away for the next time I've to change bulbs.
![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Yep it's just a "plug-and-play" plug like all the others... screwdriver and it pops right out!
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17598 ![]() ![]() ![]() |
I fitted LEDs and they were useless! I took them out again.
The incandescent bulbs provide a very broad spread of light and the overall effect is a uniform glow. The LEDs are very pinpoint and the result was a few vety bright spots on a generally dim background. It may be possible to get more suitable LEDs now, though. |
That's about the some of my expertise ![]() ![]() P.S. Why don't screwdrivers come with instructions ![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
Yep, I studied that in depth before tackling mine last weekend. Also contributed as to how my labours went. A very good post for the novice.
