Home > Puma (Tdci) > Limp mode?
S.D.
Limp mode?
Hi all, first post,so please be gentle Very Happy
Had my 2.2 (2012) for about 3 months and just about getting used to it. Problem I have tonight is that driving home the engine warning light came on and it won't go with any power, turbo's not coming in and engine is very sluggish. Is this probably the engine going into limp mode?
Question is, are there any obvious things to check out before ringing the garage?
Thanks,
Stu.
Post #513647 12th Mar 2016 6:51pm
ickle
Not sure which of these apply to a 2.2 as new as yours but:
Engine wiring loom around red lifting eye at rear of engine
Turbo loom over air con pump
And a fault code reader / reset device is money very well spent, if you read the codes and post on here several of the members will happily point you in the right direction
Good luck
Post #513664 12th Mar 2016 7:32pm
Ryderoo
England 2015 Defender 90 Puma 2.2 HT Santorini Black
Can you verify the conditions before the limp mode activated.
I have encountered twice limp mode, the result of over reving. A stop and restart have reset the limp mode, and after approx 4-5 start and stops the engine light has extinguished. Cheers Simon
I can explain it to you, but I can't understand it for you
1990 110 TD5 county, my first Land Rover - gone
2012 Discovery 4 XS SDV6 - gone
2014 Discovery 4 XS SDV6 - gone
2015 Evoque SD4 dynamic - Wife’s - gone
2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone
2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24
2021 Defender S D250 Santorini Black 110 HT - gone March 24
2023 Evoque P300e SE wife’s current vehicle
Post #513753 13th Mar 2016 1:58am
S.D.
Thanks for the replies. I was driving home from work and got stuck behind a car doing 30 mph. I gave it some when I got to the dual carriageway. After stopping and turning right at a roundabout the engine went into what I assume to be limp mode (scary). I got home and put the post up. After some searching around the forum, I went out for a spin and all seemed normal, but with the engine management light still on.
I'll go out tomorrow again and see if all is ok again after a few start-stops.
Thanks again for the help.
Much appreciated.
Stu.
Post #513761 13th Mar 2016 6:37am
Albert s
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Stornoway Grey
turbo hose
had the same problem and found that the hose to turbo had come loose (slightly) and was causing the problem.
Post #514090 14th Mar 2016 9:18am
PK1
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Turbo hose loose or has a hole in it. Defender 110 TDCi XS SW
Range Rover Sport HSE
Post #514170 14th Mar 2016 12:41pm
simon.foster
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Alpine White
Mine was a wire to the air flow sensor which was chaffing causing a short '65' plate Defender XS 110 Station Wagon
'16' plate Mini Clubman Cooper SD
'15' plate VW E-Golf
Post #514401 14th Mar 2016 10:29pm
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
had same on mine check your air flow sensor may need a clean brake cleaner is fine and a kids paint brush clean the small wire
Post #514501 15th Mar 2016 11:04am
