Home > My Defender > Broken windshield |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2073 |
Hope your ok, sounds scary.
Is your shoulder alright? Steve |
8th May 2013 8:43pm |
That looks nasty An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
8th May 2013 8:51pm |
vogue se Member Since: 24 Jan 2008 Location: Bocholt Posts: 111 |
The car was immediate covered with glass inside. Dasboard, seats, cubby box, I even found glass chips in the boot of the 90. You can see the size of chips. It was one of them which hit me in the shoulder. But no worries I'm OK.
note. This was the original first LR windshield. No replacement or whatever. It happened this morning at 8AM, I phoned Carglass at 11AM. And now at 11PM I have a new windshield properly installed at home by a very friendly and skilled Marrocan blue cullar. Many thanks to Carglass ant theire team for this service. 200% happy. Click image to enlarge Last edited by vogue se on 8th May 2013 11:18pm. Edited 3 times in total |
8th May 2013 10:08pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20175 |
Very lucky not to have gone in your eyes with all those tiny shards. On the bright side a new screen is easier to replace than damaged paint / body work. NEVER SURRENDER! ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
8th May 2013 10:13pm |
Lucky me. There was no body damage. |
8th May 2013 11:20pm |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2190 |
There has to be a reason why the defender windscreen is vulnerable to impacts . Your picture is EXACTLY the same impact as I had 6 weeks ago in EXACTLY the same place with shards of glass in the cab . The bang was like a bomb going off and was so loud that my ears went deaf for about 5 min .This is my 3rd windscreen on my 2012 2.2 since purchase in September and my 2006 TD5 had 4 screens in 4 yrs . I'm sure there's loads more defender drivers had the same scares .
8th May 2013 11:30pm |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1579 |
Just bad luck. Mine got smashed the other day on way to work. First defender one but had two on the iveco in 7 years.
9th May 2013 12:16am |
I think the manner in which it has broken is more worrying than the frequency.
I've had a couple of big stone hits on motorways in other vehicles (including Land Rover products) and not once have I had anything like what has been posted inside the vehicle. Makes you wonder if the windscreen spec hasn't changed from the 1970s. |
9th May 2013 7:48am |
How is is possible to have all these little splinters flying inside the car: I thought that windshields these days are laminated glass specifically designed so that when there is an impact like this one, no splintering takes place. Or is Pilkington Laminated in spite of its E1 marking different? You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
9th May 2013 8:12am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5587 |
The screens are laminated, but with a hard enough force will break both layers of glass.
Defenders get a lot of windscreen damage as the windscreen is so vertical, and I believe that the windscreen is weaker due to it not being a bonded windscreen, or having any curvature. Andy |
9th May 2013 8:43am |
Not got a archive photo of the windscreen lettering but found this label which is on the cab quarter light: [URL=] Click image to enlarge[/URL] I recall there was a debate on our sister site RRS regarding replacement windscreens and whether there was any difference between those labelled "Land Rover" and those not. Will look later at the windscreen as i really don't like the potential implications of a stone strike causing this. I wonder if you can fit the clear security film to a windscreen (from a legal/vehicle tech regs viewpoint) and how long it would last, especially with a heated screen. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
9th May 2013 8:48am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17240 |
That was a VERY big stone to do that. Any laminated screen will break in that way if hit hard enough by a sufficiently massive object.
If that had been a toughened screen (eg a Series LR) the object would have ended up on the seat. |
9th May 2013 4:29pm |
ppad Member Since: 16 Nov 2012 Location: now, UK S Coast Posts: 223 |
My 2005 got hit by stone on the M3 2 days ago and has to be sorted. Now, here's my q...
Back in Aus the 110 I had was ex RAAF and had 'military' grade tyres and windscreen. The tyres were road biased but umpteen ply steel and couldn't be punctured. The windscreen I recall had special markings, triple laminate or something. Again, couldn't be damaged, by anything. So, if I am keeping the truck for another 10 yrs, what are the options here in the UK ? Sold the much modified 110 2.8, in Oz Brought the 90 home from Switzerland ... |
13th Mar 2016 12:15am |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
/\/\/\ Paintwork is a bit "loud",but am sure you could paint over it.
Pov.spec,ftw. 2006, 110,TD5. Last edited by jimbob7 on 13th Mar 2016 12:34am. Edited 1 time in total |
13th Mar 2016 12:29am |
