Home > Wheels & Tyres > 285's or 265's |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3479 |
I got irritated by the crud going up the side with 285's. 1951 80" S1 2.0
11th Mar 2016 2:35pm |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1358 |
Is yours a 90 or 110?
11th Mar 2016 2:42pm |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
sorry it's a 90, I've got some new wheels (ET25) with no tyres on so was wondering if it might be best to fit the 285's to the new rims and sell the Zu's complete with tyres, saving swapping about, I do like the Duratrac's though, I've not had KM2's
11th Mar 2016 2:49pm |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
Land Rover spent over two million pounds testing which tyre size was best for the Defender in real life use and the 235-85X16" came out tops. Anything else is for looks. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
11th Mar 2016 2:55pm |
^^^ Agreed, 235's are too thin for me though. 265's look about right but I've always fancied some KM2's and don't want to miss out.
11th Mar 2016 2:58pm |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 677 |
...... Yes but in so doing they factored in cost to them, what was available in the market place at sufficient volumes to supply the volume they needed on the line, what generated the best bearing life, what gave best fuel economy to make sure they could hit their CO2 targets, and a wealth of other things. Hardly any of these things are relevant to someone replacing the original tyre really |
11th Mar 2016 3:28pm |
Availability, cost, fuel consumption, component wear are all things that I'm interested in!
My Defender isn't just for me to look at. The performance benefits of narrow tyres are well documented. However the OP was after a comparison between 265s and 285s, so that's not really relevant. FWIW going from 7.50s on standard steels to 255/85s on Wolfs I did notice a drop in turning circle (or more accurately a reduction in steering lock before I god the guddugga dugga dugga noises). |
11th Mar 2016 3:53pm |
I only wanted to know if there were any advantages or disadvantages really
11th Mar 2016 5:13pm |
Ranger Member Since: 17 Nov 2011 Location: United Kingdom Posts: 75 |
The 285's may require spacers, if not already fitted. The 285's are also a bit scary should you hit a minor puddle at the roadside at speed, can be prone to aquaplaning and pulling to the left, whereas the 265's, being slightly narrower, are a bit steadier. Easier to source 265's and cheaper too. I've had both.
11th Mar 2016 5:41pm |
Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 822 |
There's a thread a bit further down about 285's on a 90 that you may find interesting reading 😀
11th Mar 2016 6:46pm |
Thanks for the replies, I think I'll stick with 265.
11th Mar 2016 7:06pm |
Arierep Member Since: 12 Apr 2013 Location: Portugal Posts: 258 |
Don't know if it's relevant for the OP, but no one mentioned offroad behaviour.
Foi from my little experience with them, 285/75r16 air down nicely and provide quite a confy ride and good ground clearance |
12th Mar 2016 11:25am |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 |
Have 285s with spacers, do make a mess of the vehicle sides and lock stop adjusted almost to limit but no problems apart from getting balancing right if at all. With hindsight I would go with 265s. Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
12th Mar 2016 2:46pm |
Cheers jeffersJ, that settles it, I'll stay with 265's. I don't want to put spacers on tbh, I just fancied a set of wider tyres but 265's are a good compromise.
12th Mar 2016 6:45pm |
