Home > Wheels & Tyres > 285's or 265's
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
285's or 265's
I've been offered a set of 5x BFG KM2's in a 285/75/16 size at the right price, I've got 265/75/16's on at the moment.
Question is - what difference will they 285's make to the turning circle, gearing (I've already changed my ratio's to 1.2) and extra fuel or drag?
Anyone gone to wider tyres and regretted it?
Post #513210 11th Mar 2016 2:33pm
familymad
I got irritated by the crud going up the side with 285's. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #513212 11th Mar 2016 2:35pm
AJC
Is yours a 90 or 110?
Post #513214 11th Mar 2016 2:42pm
Lambley
sorry it's a 90, I've got some new wheels (ET25) with no tyres on so was wondering if it might be best to fit the 285's to the new rims and sell the Zu's complete with tyres, saving swapping about, I do like the Duratrac's though, I've not had KM2's
Post #513216 11th Mar 2016 2:49pm
RED-DOT
Land Rover spent over two million pounds testing which tyre size was best for the Defender in real life use and the 235-85X16" came out tops. Anything else is for looks. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #513218 11th Mar 2016 2:55pm
Lambley
^^^ Agreed, 235's are too thin for me though. 265's look about right but I've always fancied some KM2's and don't want to miss out.
Post #513219 11th Mar 2016 2:58pm
Matt110
...... Yes but in so doing they factored in cost to them, what was available in the market place at sufficient volumes to supply the volume they needed on the line, what generated the best bearing life, what gave best fuel economy to make sure they could hit their CO2 targets, and a wealth of other things. Hardly any of these things are relevant to someone replacing the original tyre really Question
Post #513232 11th Mar 2016 3:28pm
Cupboard
Availability, cost, fuel consumption, component wear are all things that I'm interested in!
My Defender isn't just for me to look at.
The performance benefits of narrow tyres are well documented.
However the OP was after a comparison between 265s and 285s, so that's not really relevant. FWIW going from 7.50s on standard steels to 255/85s on Wolfs I did notice a drop in turning circle (or more accurately a reduction in steering lock before I god the guddugga dugga dugga noises).
Post #513238 11th Mar 2016 3:53pm
Lambley
I only wanted to know if there were any advantages or disadvantages really Rolling Eyes
Post #513265 11th Mar 2016 5:13pm
Ranger
United Kingdom 2003 Defender 110 Td5 G4 LE Zambezi Silver
The 285's may require spacers, if not already fitted. The 285's are also a bit scary should you hit a minor puddle at the roadside at speed, can be prone to aquaplaning and pulling to the left, whereas the 265's, being slightly narrower, are a bit steadier. Easier to source 265's and cheaper too. I've had both.
Post #513273 11th Mar 2016 5:41pm
Bps
There's a thread a bit further down about 285's on a 90 that you may find interesting reading 😀
Post #513306 11th Mar 2016 6:46pm
Lambley
Thanks for the replies, I think I'll stick with 265. Thumbs Up
Post #513327 11th Mar 2016 7:06pm
Arierep
Portugal 1995 Defender 90 300 Tdi SW Alpine White
Don't know if it's relevant for the OP, but no one mentioned offroad behaviour.
Foi from my little experience with them, 285/75r16 air down nicely and provide quite a confy ride and good ground clearance
Post #513498 12th Mar 2016 11:25am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
Have 285s with spacers, do make a mess of the vehicle sides and lock stop adjusted almost to limit but no problems apart from getting balancing right if at all. With hindsight I would go with 265s. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #513554 12th Mar 2016 2:46pm
Lambley
Cheers jeffersJ, that settles it, I'll stay with 265's. I don't want to put spacers on tbh, I just fancied a set of wider tyres but 265's are a good compromise. Thumbs Up
Post #513642 12th Mar 2016 6:45pm
