Home > Td5 > AS10
dmohil
AS10
Hi, I would like to deactivate the immobilizer, but keep the alarm on my Defender. I would also like the possibility to only use the key to open doors and hopefully turn off the alarm in case my FOB don't work.
I have a Nanocom and I think I got most of it to work this way. But the alarm goes on when I open the doors when using the key. I have disabled plip and passive immobilizer.
Is it possible to have it working as I want?
Post #51306 6th Jan 2011 8:56am
lightning
No.
Post #840561 29th Jun 2020 8:59pm
Lwb97
Wales 2002 Defender 90 Td5 HT Oslo Blue
If you want to be able to open the door with the key and stop the alarm going off you need to look for the key disarm in (I think) settings group 2 and change the setting.
Post #840563 29th Jun 2020 9:05pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
you need to make sure you have a genuine land rover CDL 4 wire motor to be able to do this.
Key disarm will do the job, but you need that part above to send that information.
If you don't have the ultrasonic sensor, breaking the glass and pulling the lock up from the inside will do the same thing as key disarm. Might not be what you really want as the alarm won't sound. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
Post #840707 30th Jun 2020 2:55pm
