![]() | Home > 130 > Defender 130 double cab conversion |
AndrewS is your man to talk to....Welcome
I am sure the 130 and 110 DC are the same ![]() If I get chance tomorrow I will have a look at Longshanks and our 110 DC and see if there is a difference. 130's have feeling's as well you know ![]() |
Touchwood Member Since: 03 Mar 2016 Location: Uk Posts: 10 ![]() |
That would be great many thanks
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17619 ![]() ![]() ![]() |
Sides, back of cab (above bulkhead), and roof are the same. The floor area under the rear seat is different since the 130 doesn't have the upsweep to the chassis of the 110, and the 130 rear lower cab also has the lower bulkhead (which is part of the 110 rear tub). The 130 also has the infill panels where the 110 rear wheelarch starts.
So everything except the bits below and behind the rear seats are the same. |
Thanks for the info. I put the panels on the chassis today just to see how things sit and it all makes sense now!!
