![]() | Home > My Defender > 110 Utility Grey Update |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 ![]() ![]() |
Apparently, leaving the children in a fisher price my first tent isn't an option......I suggested leaving them with the mother-in-law.....this was received about as well as a cup of warm sick. The foxwing taking oztent sides makes sense...... I like the finished look of the hannibal with tourer kit, but am not sure it will give us all the sleeping space we need. I have been known to have the odd tipple or crate, now that Ken has pointed out that the foxwing isn't an awning but in fact a beer den, this has confused matters further. |
Sorry Ken, I am hi-jacking....will
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Ken where you planning on fitting the snooper .
Fitted well bit of an overstatement it's stuck to the screen thought they might have come up with a better way
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 ![]() ![]() |
TC, I use an Army basha (£35) with some bunge cords and some oztent adjustable poles. Connect this to the roof rack with the bunge's and we can put it on either side of the vehicle and alter it to prevent driven rain etc (as per second pic), I have brought another basha to connect to the bottom of the roof tent so I have cover from the front of the vehicle up to the ladder of the roof tent
![]() ![]() ![]() Click image to enlarge ![]() |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 ![]() ![]() |
Love your resourcefullness Tone
Thx steve
![]() The Basha already has eyelets and strong webbed loops down all four sides. I use 4" bunges which are used to fix (monoflex) sheeting around scaffolding, put the bunge's throught the webbed stiched loops and around the side of the rack. Holds the Basha in so tight and close to the rack no rain or water gets in behind it. There are also webbed straps running across the Basha in the middle so I run the horizontal oztent pole through this to stop any sagging. We had some proper rain in the ALPs and Lakes and it worked a treat, you can mess about with the pitch or angle of the basha, moving the poles up and down and adjusting the guide ropes, also acted as a privcy screen or wind break when we did not need an awaning. we wild camped in Switzerland in a forest and I tied it between two trees to hide the vehicle from any onlookers, so many uses ![]() Further more the Basha is 2.3m wide so perfect for a full length rack ![]() |
Have moved my questions off here Overland Set Up
Sorry for the hijack Ken ![]() |
jlprojects Member Since: 10 Dec 2010 Location: now in Ireland Posts: 48 ![]() ![]() ![]() |
Ken, I'm doing a 2" lift soon and changing my wheels to the same beadlockers you have. Have you any issues with rubbing or did you have to fit spacers? John
John no spacers used
Ken, Thanks for the information, I'll get 5 when I get back to the UK. Thanks for the help.
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3150 ![]() ![]() ![]() |
I had the pleasure of seeing this truck in the metal last weekend, its very nice indeed! 2011 110 USW
1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
Were you at Lookers then
Rose between Thorns
![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
