Home > Wheels & Tyres > 255/85r16 options
Page 2 of 5 <12345>
Philslandy
Germany 2002 Defender 110 Td5 SW Epsom Green
Jose,
i have the BF`s on HD Wolf rims.
Before mounting the new tires and rims, the Wolfs have been in the paintshop - no rust till now
Here a pic allready some years old (it`now even looking better Laughing 9
Cheers Philip
Post #512336 9th Mar 2016 9:37am
jst
i have run BFG MTs 255.85R16 for the last 12 years or so i guess. KM and KM2s.
they worked well on Wolf rims on a 110 but the inner arches just caught on the rear on full articulation (std height/suspension)
also worked well on boost alloys and currently running a set on Mach 5s.
for mud/wet fields i wouldn't use anything else on a vehicle that spends most of its time off tarmac.
for a vehicle that spends the majority of its time on road i would use BFG ATs. i have a set of 265.75 AT KOs on a alloys (freestyle) on a 90 and a set of 235/85 on Boosts on a 110. Both are superb on tarmac, quiet, wear well and far better road manners than the MTs (both KM and KM2) as you would expect.
For gravel tracks, rocks the ATs are bloody good, surprisingly so and i highly rate them in grassy fields too but not to same level at the MTs.
i have just ordered a set of 285.75s for the Soft top project in BFG AT KO2 format.
up until a year ago i have only used BFGs on my landrovers.
last year i had a set of GG ATs, 275.55R20s - now they are a good tyre too, not tried them on a defender but very impressed with them on wet grass/tracks. But not as good as the BFG ATs. if BFG did that size in AT i would of had it in a second. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #512347 9th Mar 2016 10:08am
Arierep
Portugal 1995 Defender 90 300 Tdi SW Alpine White
Thanks for all the help,
Like I said, my main problem with the Wolf rims is if I want to mount 285/75r16 in the future due to 255/85r16 scarcity.
In the US they seem to mount 285/75r16 on 6.5J rims all the time, but who knows.
On the tyre clearance department, my current 235/85r16 nearly touch the arches in full articulation, so the bigger tyres will rub for sure. To address this I'll move down the travel 50mm with droppers and longer bumpstops and lift the suspension 38mm*. Probably will go with spring spacer blocks, as longer spring travel would be wasted with the long bumpstops.
What do you think?
* Why 38mm? I currently have 12mm Discovery rubber spacers which I'll remove since they were only effective in the first week or so. +50-12=38mm
Post #512437 9th Mar 2016 2:36pm
jst
is this on a tdci? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #512590 9th Mar 2016 9:03pm
Arierep
Nopes, it's a 300TDI
Post #512594 9th Mar 2016 9:11pm
Arierep
Was looking at the Aborderlessworld expedition 110 the other day, and the guys say they were using 255/85R16 KM2s, but don't they look way more massive?
! images used without permission!
Post #515910 19th Mar 2016 2:51am
camelman
The tyres in those pics are 37 inch KM2s not 255/85/16.
On their website it shows their truck with the 255s on initially but the photos further down show them cutting the wheel arches to fit the 37's in.
Post #515982 19th Mar 2016 4:04pm
Arierep
Thanks Camelman,
Missed hey mentioning that size in their website, should it be 37x12.5R17?
Never saw anyone overlanding that way with such big tyres
Post #515985 19th Mar 2016 4:38pm
camelman
Looks great until you shred one and need to find a replacement in the bush Smile
Post #516145 20th Mar 2016 10:14am
jst
255.85s R16s MT BFG on my grey 110 here std suspension, wolf rims. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #516249 20th Mar 2016 9:40pm
jst
also on the white 110 too Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #516250 20th Mar 2016 9:40pm
Arierep
Well, I can't really decide between the KM2s and the Toyos, so I'll just pick the ones that have the better discount at the time I change tyres.
Now I just need to decide if I keep my 16x7j modular or switch for the Wolf ones.
Any opinions on this?
Modulars:
- wider track (24mm total)
- better width for a possible future 285/75R16 change
- already have them, should save around €200,00
Wolfs
- stronger?
- have the original LR look I like
- should have better rust resistance
Post #517633 25th Mar 2016 11:03am
jst
personally i would stay away from modulars they are just not strong enough in my experience and deteriorate quickly Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #517775 25th Mar 2016 9:23pm
Mdm
recommended size for 255 is 8 inch rim
there is a tolerance to 6.5 -8 inch rims
amended as my local ats gave slightly different advice
Post #517805 25th Mar 2016 10:35pm
Retroanaconda
6.5" - 8" for 255/85/R16 according to BFG website, so Wolf rims are fine.
http://www.bfgoodrichtires.com/tire-select...re-details
Post #517817 25th Mar 2016 11:26pm
Page 2 of 5 <12345>
