Home > Off Topic > bench drill/grinder
leeds
bench drill/grinder
Am looking for bench/pillar drill also grinder.
Any recommendations or things to avoid.
Light duty use rather then busy every day manufacturing
Brendan
Post #50921 3rd Jan 2011 10:43pm
RLD
just get the best as you know it makes sense have a look oat Machine mart or screw fixe plenty to go at there RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #50928 3rd Jan 2011 11:08pm
leeds
Currently thinking of either the Axminster ED 16SB or the ED 16B2 Pillar Drill They can be found HERE
Trouble is I am used to drills in a physic dept research workshop. Those drills were 3ph and a long chuck travel. Those at Screwfix are a bit of a joke in comparison.
If anyone has any comments/suggestions would like to hear them.
Drill has to be single phase. Have tried the local surplus machine suppliers without luck
Brendan
Post #51038 4th Jan 2011 8:12pm
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
We have this one at work, but dident last long, base broken and chuck shaft falls out!
http://www.axminster.co.uk/axminster-plus-...prod22287/
Post #51040 4th Jan 2011 8:38pm
RLD
Shocked though they only made carpets RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #51044 4th Jan 2011 8:57pm
stevie d
United Kingdom 2003 Defender 90 Td5 SW Alpine White
Try Sealey, make good stuff Thumbs Up
Usually mid price range and often very good warranties. Defender 90 TD5 Station Wagon
Discovery 3 HSE
BMW 330i Coupe
Post #51050 4th Jan 2011 9:26pm
mick
Give R&M Sutcliffes at Soweby bridge a call they may know where there is a second hand machine .
Post #51076 4th Jan 2011 10:35pm
leeds
Thanks Mick, called in at RM Sutcliffe today and got a bench drill,
Certainly better quality then Screwfix, not as good as the ones I used to be able to use in the research workshops.
Made job of altering roof tent clamps a lot easier.
Thanks Mick
Brendan
Post #51182 5th Jan 2011 6:45pm
mick
No problem glad you are sorted they are a bit droll in there but seem to have most things at a good price another good place is BAP at brighouse for bolts etc Thumbs Up
Post #51187 5th Jan 2011 7:01pm
leeds
That is another thing I have got to source. Managed to get hold of some twin battery trays but the bolts are 8 x 150. Could do with some 8 x 160 but can't find them in UK. Can get some from France but they want 20 euros P & P. Can get some 8 x 170 at global surplus but silly money is wanted.
Most bolt suppliers say 8mm stop at 150mm but I do have a couple of 8 x 160 in lock up but have no idea where I got them from
Brendan
Post #51195 5th Jan 2011 7:27pm
RLD
just get some 8 mm threaded bar and cut them to lent you can get EN8 stuff strong not just mild steel RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #51196 5th Jan 2011 7:34pm
mick
As Ray says theaded bar weld a nut on one end any length you want.
Post #51198 5th Jan 2011 7:46pm
leeds
There is only one slight flaw with that plan! Razz
I can't weld Big Cry
Also nice BZP will be more attractive.
Am going to Leeds tomorrow so that a friend can weld some bolts onto the modified clamps for this roof tent. Will be picking some ali flat bar on my way for the bottom clamp.
This is all because an X trail roof bars are wider then standard.
Brendan
Post #51205 5th Jan 2011 8:31pm
RLD
just put 2 nuts on one end and tighten them up together you then have a bolt RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #51208 5th Jan 2011 8:47pm
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
So simple and you just gave me a solution how I was going to resolve my twin battery bolt dilemma.
Thanks Ray Thumbs Up
Post #481947 14th Dec 2015 8:03am
