Home > Puma (Tdci) > Won't turn over. Cant connect to OBD. No main beam/dip |
you jump a wire across power side ok can you tell if power is getting too coil from ignition switch side i would test the relay out of the socket i had relay fail i.e. coil open cct also check switch side of the relay too
4th Mar 2016 4:24pm |
Soupy Member Since: 05 Dec 2014 Location: Aberdeen Posts: 68 |
That's me officially out of ideas.
Removed the ECU, checked all connections and earths etc. Ran some new ones direct to the battery earth. Still nowt. Taking it to a local Land Rover Specialist tonight. Hopefully won't cost too much. |
7th Mar 2016 2:00pm |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2035 |
Hope you get it fixed without to much cost. Let us know what the problem was when you get it sorted.
7th Mar 2016 3:39pm |
So, the independent LR specialist fixed it. ( Kirkstyle garage in Kemnay Aberdeenshire).
Dodgy wiring somewhere. No way I'd have managed to fix it myself. I went round while he was at it, he had all sorts of electronic gizmos attached to the vehicle. No parts needed just a length of wire. |
22nd Mar 2016 3:28pm |
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 |
Brilliant I started with nothing and still have most of it left!
22nd Mar 2016 4:01pm |
good ( independent LR Aberdeenshire specialist to rememder ) |
22nd Mar 2016 5:28pm |
