Home > Technical > Tow bar wiring |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
7 pin sockets are total rubbish though.
The potential to fail an MOT should not be a reason to avoid the 13 pin socket, which is electrically and mechanically vastly superior to the terrible 7 pins. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
14th Feb 2016 7:14pm |
I would far rather have tow electrics tested anyway. It seems mad to fit 7 pin electrics just so a fault in them would not be tested for at MOT time.
This is about safety and consideration towards others; I bet we've all seen trailers with faulty lighting. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
14th Feb 2016 7:32pm |
nmj Member Since: 07 Feb 2016 Location: Hertfordshire Posts: 65 |
had the tower electrics fitted today with the socket fitted in the rear cross member, really pleased with that , also rear work lamp fitted to roof rack, shame the holes in the supplied bracket are in the wrong place so have currently spaced the bracket away from the roof rack , will have to extend the holes at some stage
1st Mar 2016 12:59pm |
LoveTheMud Member Since: 19 Feb 2015 Location: Weybridge Surrey & Pontefract West Yorkshire Posts: 411 |
I fitted this as my first ever modification (D90 64Plate) - 13Pin - so its pretty straightforward but quite fiddly behind the switches - I wired it into the rear heated window switch. If you get any questions as you are doing it, PM me as I can probably help.
First off, there is a socket behind drivers side rear lights - most of the wires go in here - dead easy Second, wires and relay into the battery box - one wire to the battery I think and one into the relay. Wire from the relay into the back of the switch - run on the outside of the gearbox Cheers Michael |
1st Mar 2016 1:11pm |
thank you but all sorted now , will sort the rear lamp bracket out another day, i cheated and wired it in to reversing lamp , thats good enough as in reality its never going to be used for its true purpose . booked the Adventure in for a couple of weeks time with Urban as i have decided i need rear park sensors on the little truck !!!
1st Mar 2016 1:20pm |
also i fitted the 13 pin socket but will never need some of it as i won't be towing a caravan so all plugged in on the o/s
1st Mar 2016 1:22pm |
meeerrrk Member Since: 12 Feb 2017 Location: Surrey Posts: 548 |
Did you fit the socket in the cross memeber? It really bugs me that it isn't fitted in the hole.
Is the only method to drill the crossmember and fit rivnuts into the holes? |
21st Feb 2017 10:30pm |
Swac3 Member Since: 21 Feb 2015 Location: Aberdeen Posts: 363 |
Or drill the crossmember and screw in self tappers, or was that just me.
That said 2009 !! Just shows how much JLR care/think that anyone buying a defender after then still gets 7 pin electrics. 3 Landrovers Last edited by Swac3 on 21st Feb 2017 11:06pm. Edited 1 time in total |
21st Feb 2017 11:03pm |
I guess you could, does it not have a tendency to come loose / pull out when you unplug the connector?
21st Feb 2017 11:05pm |
Never has nope, To be honest i'd be more worried about the ability to remove the screws now than of them coming loose 3 Landrovers
21st Feb 2017 11:08pm |
dashed Member Since: 12 Jan 2015 Location: Manchester Posts: 29 |
Whoever fitted the plug and play electrics in the factory in mine had been having a good laugh - it was tucked so far up under the wheel arch spray cover that I was convinced it wasn't there. Took ages to locate and could only just reach it!!
22nd Feb 2017 10:42am |
They have a trim clip that holds the plug in place, so they should all be in the same place.
22nd Feb 2017 2:36pm |
InternationalDBA Member Since: 18 Feb 2018 Location: West Sussex Posts: 19 |
I am fitting a new chassis and I have a question about the towbar wiring.
The 7 pin wiring which plugs into the loom is straightforward. However, the extra wire which comes from the battery box has a branch with a socket at the end. Where do I plug this in or do I just secure it safely out of the way? |
28th May 2024 8:06am |
