Home > Wheels & Tyres > 7jx16 5-165pcd et08 max load 3200lbs 01 09 |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 |
i believe they will.
7" wide rim (235>265 tyres) 16" wheel (for the majority of LR tyres and LR std fit) 5x165 is the right number of bolts and the spacing (PCD) for a defender ET08 is a reasonable offset so will be entirely standard for a steel wheel. on a 265 tyre it will be slightly inside the wheel arch. 3200lbs is a good load rating. do you like them? |
29th Feb 2016 9:34am |
Kent_keith Member Since: 01 Jun 2014 Location: Kent Posts: 388 |
Thanks Mike, I was going to buy a set of eBay and I needed to be sure 2005 TD5 90 CSW XS
29th Feb 2016 9:32pm |
