Home > Off Topic > Tyre regroover.
RED-DOT
Tyre regroover.
Rillfitt 4 tyre regroover/cutter with two boxes of blades. German 240V unit with four settings. No longer made but regarded as the best tool ever made. Had one hours use.
£300.
"RILLFIT4 is another German cutter, it has 4 heat settings and is generally regarded as top of the tree, it does the same job as all the others in much the same manor and the low voltage cable is more flexible than the (tiptop) it is ideal for long continuous use with the same slide action as the above to supply heat to the blade, total weight is around 7 kilo and the sturdy gun and jaws are less than 1.5 kilo, will take the same verity of blades, 240v... or 110v " 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #509335 29th Feb 2016 8:05pm
