Home > Td5 > Clutch pedal |
slave and or master cylinder leaking or seal braking down color of clutch fluid black or discolor indicates seal failure or fluid contamination water and so on (clutch and brake fluid is hygroscopic)
if ever slave or master has failed, good practise to changed both as if one has failed the other one will to sooner or later Last edited by dorsetsmith on 29th Feb 2016 6:45pm. Edited 1 time in total |
29th Feb 2016 4:47pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 950 |
Also check your return spring it might have broken or slipped off. Item 10 in pic (if it is an older model year)
Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
29th Feb 2016 5:34pm |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
New master and slave cylinder time.
29th Feb 2016 5:42pm |
Cheshire Dave Member Since: 05 Jun 2014 Location: Chester Posts: 119 |
Sorry guys I should have put this in TDI section but I suppose it's the same outcome, looks like a trip to my local mechanic !
Dave |
1st Mar 2016 7:59am |
same problems tdi 300 or td5
1st Mar 2016 8:32am |
SteveK Member Since: 21 Jan 2015 Location: Bromsgrove Posts: 333 |
Probably the master cylinder, but as others have said, change the slave at the same time.
Use good quality replacement cylinders, those that come in a blue box may not last very long!. |
2nd Mar 2016 12:37am |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
Another thing it could be though I would say if the fluid level hasn't dropped it would be a good second thing it could be is the clutch release fork starting to go.
That said they usually go and go terminally- best get your master and slave seals checked first! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
2nd Mar 2016 12:46pm |
