Home > Maintenance & Modifications > fitting a NAS rear step |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
Normally the question is will the Nakatanenga wheel carrier fit with a NAS step.
The answer is yes to a genuine NAS step, although the main bracket of the wheel carrier might need a firm push down behind the rubber of the NAS step. Sometimes the rubber step needs a slight trimming. Fitting a genuine NAS step should be straightforward. HTH Brendan |
26th Feb 2016 9:17pm |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello potspeedy
I have a NAS Rear Step with a Mantec Spare Wheel Carrier...(which also fits) Looking at your photo, and what looks like your Dixon Bate Adjustable Slider / Tow Hitch, which will fit to the NAS Step but will require some creative metalwork to brace at the lower section of the set-up as the whole assembly projects further back from the cross member / chassis with the NAS Step fitted...one additional thing to think about... Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
26th Feb 2016 10:24pm |
As your naka wheel carrier is the earlier type it take quite a bit of modification of the wheel carrier bracket as I found when I fitted mine.
Click image to enlarge Click image to enlarge I had to take even more off than this Ray My build thread http://www.defender2.net/forum/topic17615.html |
27th Feb 2016 12:18am |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
If you're not afraid of a grinder and a lick of spray then it'll fit. I made my nas style step fit to my nak single arm, made similar cuts to the above post. More needs a trim to seat it flush but its on the list of things to do 👍
27th Feb 2016 2:37am |
potspeedy Member Since: 13 Feb 2016 Location: Bucharest Posts: 14 |
Thanks guys.
Well, I'm not afraid of a bit of grinding...I will order an Nas step and fit it but that's my last concern now as I had to take out the engine... I will make a separate post about. |
27th Feb 2016 9:33am |
