Home > In Car Electronics > Fitting tweeters - TD5
excossack
On my TD5 110 I have speakers just above the B Pillar in the headling and that's it. Now got a pair of tweeters but where to fit and how?
Do these wire in direct from the speaker feeds, so into the speaker with two wires and then two wires out into the tweeter? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #508245 25th Feb 2016 9:06pm
JWL
I put a pair of tweeters in my Td5, they're in their own golfball type cases and they sit on their sticky bases at each end of the crash pad. As I've still got speakers on the lower dash panel by your knees I joined the wires on the tweeters to the nearest speaker so I just piggybacked off the fronts.
Post #508289 25th Feb 2016 10:22pm
If you find a photo of a Puma dash you'll see the mounting they have on the dash top at each end.
You could copy that and would look pretty factory too.
You can indeed piggyback of the front speakers as mentioned above.
Post #508290 25th Feb 2016 10:25pm
grafty99
This is the only picture I could find of my dash, tweeters in the puma location Thumbs Up
 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #508307 25th Feb 2016 11:16pm
That's the one. Thumbs Up
Post #508321 25th Feb 2016 11:50pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
grafty99, what are you running in your lower dash for speakers? it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #508327 26th Feb 2016 1:34am
excossack
Thanks peoples. So in relation to the speakers, does it matter where the tweeters go? With my speakers behing by the top of the B pillar, will the tweeters need to go near there? 1999 Defender TD5 110
Regards
John M0VAZ
Post #508346 26th Feb 2016 7:37am
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Best improvement you can make is to not use the speakers in the headling above the b pillars and mount speakers in the dash as the photo shows. The headlining speakers are too close to your ears !!
Post #508355 26th Feb 2016 8:14am
excossack
I did think about moving the speakers but don't want to cut holes in the dash board. 1999 Defender TD5 110
Regards
John M0VAZ
Post #508359 26th Feb 2016 8:32am
mk1collector
Tweeters need some form of crossover so don't just wire them from the head unit or other speakers. I also fitted mine to the top of the dash as above. Ray
My build thread
Post #508381 26th Feb 2016 9:35am
They should have X overs wired in-line.
Post #508392 26th Feb 2016 10:19am
excossack
Do the ones from a Puma Defender come with crossovers built in? 1999 Defender TD5 110
Regards
John M0VAZ
Post #508408 26th Feb 2016 11:53am
mk1collector
I've not actually seen any but they will have a little resistor soldered t the body of the tweeter Ray
My build thread
Post #508414 26th Feb 2016 12:08pm
Martin
Site Admin
Yes Puma tweeters have crossovers built in  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #508426 26th Feb 2016 12:51pm
As Martin said, built in on Puma tweets, and most likely on some aftermarket models too.
On my Kicker one's it is in-line instead.
So long as there is an X over present that's all that matter.
Post #508523 26th Feb 2016 7:59pm
