![]() | Home > Maintenance & Modifications > Winches |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
Just so that I'm clear. Goodwinch (which seem very good value) are deemed acceptable and not "el cheapo", yes? If I get a winch it'll only be for occasional use. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
My PowerPlants ore OK. Had an issue in the early days with water ingress into the 'sealed' solenoid packs. This has been resolved now and everything was replaced FOC. Also had a problem with corrosion on the head of the compressor, again this was replaced FOC. 130's have feeling's as well you know
Alan, not el cheap at all. Good value, great productt
I certainly will not put David Bowyer stuff in the el cheapo bracket.
Really mean the winches on ebay for a couple of hundred £.. yes have seen them fail David Bowyer has a good reputation and gives good advice. The videos on his website are worth watching as well. On red 110 we have two Warn 9.5. They were bought when the price on Warns were more respectable. Have a Warn 9500 on black 110 but got that as the price was right. If was in the market now for a winch David Bowyers would probably head the list. Brendan |
Surrey Rover Member Since: 20 Dec 2010 Location: Surrey Posts: 360 ![]() |
Anyone got any experience or thoughts on PTO hydraulic winches like the REd Warrior?
I want a winch for moving around tree limbs and butts. I have heard that the electric ones even the Warns burn out in this situation, any comments on this welcome. |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 ![]() ![]() |
Surrey, PTOs are the way forward if your using the vehicle as a real work horse, im guessing your a tree surgeon
![]() Electric winches are great but if your using them everyday to shift stumps etc, the PTO is far more efective as its driven directly from the engine, most of the utility company defenders are fitted with PTOs for this reason. Not cheap mind but pretty bomb proof. You cannot teach stupid people to do clever things |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
Correct Alan,, For a self recovery winch, to be relied on, for occasional use,, speak to David at Goodwinch, as per the link i did earlier in this thread I run 8274's at either end of the challenge truck, and best choice for the centre was a TDS,, all are overvolted ![]() Surrey Rover,, If you need a winch all day, every day,, its hydraulic or PTO,, Great bunch of chaps at Red winches, very nearly tempted to chance over to their hyd winches, but still retain the TDS as the middle California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Thanks Discocuzzy & TJ,
Looks like I am not going to get much change out of 2K by the time I have added the bumper! Damn these Land Rovers eat your cash ![]() |
BIGFOG Member Since: 12 Sep 2010 Location: Edenbridge Posts: 537 ![]() ![]() ![]() |
Hi Surrey,
It would be worth talking to Gigglepin as they should be relatively near to you and I know they have supplied/specced/upgraded winches for several tree surgeon customers. They also stock both Warn and Goodwinch. |
