![]() | Home > Maintenance & Modifications > Engine management light on again |
Ryderoo Member Since: 28 Aug 2015 Location: South Oxfordshire Posts: 1666 ![]() ![]() ![]() |
May not be that bad Leeroy...........
Mine went into limp mode when I was racing a 1 series Beemer. ![]() Engine light came on, I had over revved. ![]() Pulled over, switched engine off, restarted full power recovery. ![]() Engine light went out a few days later. ![]() No problems since. Cheers Simon I can explain it to you, but I can't understand it for you 1990 110 TD5 county, my first Land Rover - gone 2012 Discovery 4 XS SDV6 - gone 2014 Discovery 4 XS SDV6 - gone 2015 Evoque SD4 dynamic - Wife’s - gone 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 HT - gone March 24 2023 Evoque P300e SE wife’s current vehicle |
Leeroy Member Since: 01 Aug 2015 Location: East Yorkshire Posts: 261 ![]() ![]() ![]() |
Cheers Ryderoo
I hope not ![]() I will let you know how I get on and hope your light stays off and ok Cheers Leeroy |
Hose leaks
Now in with the dealer to find which one and whilst its in there is a slight weep from the timing case and the parking break light just flickering on and off all the time and the function was fine and the break fluid level was fine possible faulty switch. |
