![]() | Home > Tdi > 300TDI sump replacement |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 ![]() ![]() ![]() |
It can be changed in situ but the oil pick-up in the sump makes it tight to remove. Lifting the vehicle on the chassis helps to create a bit more space over the top of the front axle. Use appropriate axle stands etc.
It's a messy job, I have to do mine soon ![]() Try putting a wanted ad up on a few forums, I picked up a good condition sump for £30 last month. There are dented ones on Ebay going for 3x that ![]() |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 579 ![]() ![]() ![]() |
I picked one up form the auto jumble at Billing for 40 squid,when I stripped the drain plug.
It was a right pig to get the old one off as it had been stuck on with sealant. So after cleaning it off I put it back with Hylomar.....Big mistake. ![]() Hylomar isn't up to the job of sealing a sump.It leaked. ![]() At least the sump came off easily after using Hylomar. Access to all the 10mm bolts is easy with a couple of extension bars,so that the ratchet is below the axle.I had no problem withdrawing it backwards once all the bolts were out,though my truck has a 2" lift,it may be a little tighter on a standard truck. Good luck Marc |
![]() ![]() ![]() 322.00 Pounds I didn't realise they were that expensive for a new one. Here you go...... http://www.ebay.co.uk/itm/LAND-ROVER-300-T...SwzgRWuyvT Marc |
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 845 ![]() ![]() ![]() |
Thanks guys
![]() Doesn't sound too much of a drama, I may lay a bit of old carpet on the floor before I start though , Just gotta find a good used sump or nite the bullett and buy a new one ![]() Thanks again |
Top Secret 90 Member Since: 24 Feb 2016 Location: Trinidad West Indies Posts: 5 ![]() ![]() |
Hello ,im the new guy Ryan , i don't think you have to change the sump , just clean both surfaces properly , with some spray cleaner, or gasoline , apply thin coat of gasket silicone circle to bolt holes (grey silicone )and re install , use lock tight on the bolts . that should work , i had same problem ... Another Day In Paradise with my 90 Member of Trinbago Land Rover Owner Adventure Club.. |
womble Member Since: 27 Jan 2012 Location: south east Posts: 272 ![]() ![]() |
well,welcome to rhe forum and 1 request.............send us some sunshine please and make sure it's hot
Thanks ...as for the sunshine , you need to come down .. and visit maracas beach ... Another Day In Paradise with my 90
