Home > In Car Electronics > TDCI Style switch holder/sockets
Page 2 of 2 <12
kipperthedog
Or why not stick with pre 2002 OE type rocker switches.......
http://www.carbuildersolutions.com/uk/iva-...green-lens
The connectors are a couple of quid on top and can be had from Merlin Motorsport.
Post #412593 31st Mar 2015 8:43am
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
Defender Puma Dash Double-switch Bezel
Know this is an old thread but have any of you used this 2 switch solution on the Puma dash so you can use OEM switches rather than Carling ? http://www.ebay.co.uk/itm/Defender-Puma-Da...SwNphWYcXF
Post #485667 26th Dec 2015 10:43pm
Stiff1
I looked into this for a while until I hit on the above 2 switch option, works perfectly, I got two of them.
Post #486039 27th Dec 2015 11:28pm
Hairysteve
Thanks Stiff1 Rolling with laughter
Post #486147 28th Dec 2015 10:25am
Matt110
Go Beyond wrote:
munch90 wrote:
Didnt fcx fit 3 switches in a cubby box that fitted in a puma style bezel with puma switches
We use the parts from a genuine puma dash which is what Shaggy is trying to avoid and the minimum is three unfortunately.
I did have a lead on individual holders, I'll chase it up and report back Thumbs Up
Bit of a resurrection but which puma dash parts did you use? I need 9 switches in 3 rows of 3, so that would be ideal.
Got any photos of how you did it?
Desperate to use OEM switches.
Post #506349 20th Feb 2016 10:17am
mcma1
Look at my 110 build thread, you get 3x3 out of a puma dash centre. I have a batch of singles I will be making available next week, if they are of use I will do a 3 switch pod. Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #506483 20th Feb 2016 9:08pm
Matt110
Certainly what I'm after. Will watch with interest!! Thumbs Up
I don't have any spare dashes around but see how you did it now that really is a good way to do it and great attention to detail. The number of things I need to switch I would need 3 dashes to do mine, 6 rows of three, which might get expensive doing it with dashes I guess. Just re-read your thread and seen how you've 3D printed those singles, that's an awesome toy!!
Post #506504 20th Feb 2016 9:36pm
Stiff1
The stuff Andy is doing at the moment is amazing and am awaiting the three switch holder and a few singles eagerly.
For your needs though, have you seen the Discovery holder, takes 6 standard switches in one go for £10. 3 of those would do you although what you are doing with that many switches...
http://www.ebay.co.uk/itm/Discovery-2-TD5-...1514308282
Post #506572 21st Feb 2016 12:15am
Matt110
Thanks for the thought, did come across the 6 switch holder, you can buy them as land rover OE parts for about a fiver brand new from lots of places but the problem is that if you put them in a cubby box the switches would sit proud of the front of the surface you are mounting to. The only way to get a decent finish would be to recess the whole disco 2 unit into the cubby box, mounting it inside another bespoke ally carrier or similar so the front of the switches then sit flush with the leatherette. Other than that it's the perfect solution but admittedly even if you do this you don't have the "surround" to the switch, which mcma's ones have by using the dash fascia or printing them Very Happy Cool
Post #506588 21st Feb 2016 8:58am
Page 2 of 2 <12
