Home > Puma (Tdci) > Intermittent Engine Knocking and Other Stuff |
Treebeard Member Since: 27 Jun 2012 Location: Forest of Dean Posts: 40 |
We had knocking on a 2007 tdci especially with power on in the lower rev range 1700 - 2000 ish. Plus the injector learn fault. When the garage tried to do the injector learn cycle it kept stopping part way through. The reason was that the fuel pressure relief valve had blown ( it is a one shot device). Once replaced, the injector learn cycle ran all the way through and the engine ran smoothly. We were told that tdci's that are driven gently especially on short journeys can need their fuel prv's changing regularly and that we should give it a good thrashing once a week.
18th Feb 2016 10:42pm |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 705 |
You have to thrash them?! Seriously?! Well, a friend of mine did say you have to drive the Pumas angrily as they love that. Looks like I was wrong with the gentle touch. Go figure.
I'll look into the fuel pressure relief valve then. Thanks Treebeard! Will keep you all posted on what I find. By the way, where does one find the fuel pressure relief valve? |
19th Feb 2016 4:41am |
I have 78.000 KM now. 90% of that are 10 to 12 KM journeys locally here, with speeds upto 60KMH, no trashing ever, purring happily at 1200 to 1500 RPM most of the time. Never had any problem. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
19th Feb 2016 5:44am |
Eau02467 Member Since: 20 May 2015 Location: Glasgow Posts: 48 |
To go back to the original post it sounds to me like someone has swapped an injector at some point and not bothered to do the learning at all, you need to code the injectors in before the learning can be done. This is likely what is causing the engine knock, I wouldn't go looking at anything else until you have recoded the injector and had the learning done.
The EGR faults are unrelated and it is likely you will need to clean / replace the EGR. This will cause rough running and lack of power but unlikely to cause diesel knock |
19th Feb 2016 8:47am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17207 |
Never believe anyone who says that an engine needs to be "thrashed" in order to run properly and reliably! The pressure relief valve is fitted to the rear end (ie bulkhead end) of the common fuel rail. If it has failed I would expect to see irregular HP fuel rail pressures being reported via DTCs. The injector learn may fail if the engine is not at a sufficient operating temperature (I think it's 78 degrees min) or if the VCV on the fuel pump if defective or in need of calibration. A defective VCV is a very common cause of a wide range of running faults and often will not produce any DTCs. |
19th Feb 2016 10:34am |
Hi Eau02467, This is what we are hoping happened and will try to do the injector learn within the next few days. Funny enough, after driving aggressively for a few weeks now, the EGR has decided to work again and reading faults through the OBD scanners verify that the no faults from the EGR, seems to be just the injector learn now. Hopefully, that is all that is needed. |
10th Mar 2016 10:05am |
Hi blackwolf, Will consider the VCV as a suspect as well then if the upcoming injector learn doesn't work well. So we'll look at the fuel pressure relief valve and the VCV if the injector learn does not work. How will know if it's the VCV that's giving us issues? |
10th Mar 2016 10:09am |
Clues to a defective VCV are (a) poor running in the absence of any other DTCs, (b) irregular fuel rail pressures. The only real proof however is to replace it, carry out a fuel pump calibration cycle, and see if the problem has gone away.
10th Mar 2016 11:31am |
Hi blackwolf,
The engine isn't running poor, it just has knocking every now and then. Annoying. Now that the EGR decided to wake up, the engine is back to almost normal sound but you can still hear a distinct knock like before when I got it. So hopefully not the VCV? |
11th Mar 2016 1:52am |
OK, update!
The truck no longer knocks and drives like a totally different vehicle now! All we needed to do after all is said and done (long story short) was to initiate a Pilot Correction Learning. Apparently when one of the shops I went to tried to upgrade the firmware on my ECU, there were a few catches and the update was aborted but being as such, affected the performance of the truck. Now all is well and I can't believe the difference! I guess I've been driving the truck in his inefficient state for so long I forgot how the proper feeling was! (If that makes any sense) |
11th Mar 2016 8:54am |
