![]() | Home > Puma (Tdci) > Thoughts on cranking delay. |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
Starter degradation for sure. It will get worse. Clutch dust can cause a failure too. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
If I turn the key straight to crank from off then I get a delay to let the computers catch up.
If I turn the key to on, wait for a bit, then to crank it immediately cranks. Are you saying to turn on, wait, turn to crank, wait, then it cranks? |
Riccarton Member Since: 10 Aug 2015 Location: Gods' Own Country Posts: 280 ![]() ![]() ![]() |
At the risk of sounding stupid is the OP sure this isn't due to the colder weather?
Would I be right in thinking that if it's below a certain temperature then the vehicle gives the glow plugs a head start?? |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2774 ![]() ![]() |
Do you wait for the glow plug light to extinguish? Important to do if you aren't already. Don't just hop in and turn straight from 0 to start Cheers, David
Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 251 ![]() ![]() ![]() |
Mine does that. I put it down to the reader coil looking for the transponder. 1953 80"
1987 mini city e 2011 90" |
Even when warm temps, my glowplug light will come on for about 4 to 5 seconds, a bit longer when it is really cold outside. Understand you have to wait until the light goes off, only then start the engine. Hearsay it is not so good if you crank the engine while glowplug light is still on. Now, I am the first to admit that very occasionally I forget to wait, but no delay at all then. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 566 ![]() ![]() ![]() |
Had the same problem with my 2003 Disco TD5, turned out to be a loose battery terminal. Check your earth connections maybe? “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
-- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
Given that the glow plugs are designed to operate for a period of time after the initial light extinguishes for emission purposes, and again during an active dpf regeneration, then it will do no harm during cranking. In fact the initial pre-heat up phase is so quick with a modern glow plug that it's possible to nearly ignore it - maximum preheat time of 2.1 seconds at -20 �C (-4 �F) or lower and at temperatures above 20 �C (68 �F) there is no preheat phase (2.2 engine). Last edited by Supacat on 18th Feb 2016 3:39pm. Edited 1 time in total |
My glowplug lights take about 20 seconds to go out?
And on the 57 plate diesel Corsa we have at work that's about 10 seconds, if you just try and start it without the glow it winds over for ages. |
Sorry
![]() Not sure why it could hurt but folks get there facts from somewhere and could know something I don't ![]() |
For the 2.4 engine the following is supposed to apply: "There is a maximum preheat time of 8 seconds at -20�C or lower. At temperatures above 80�C there is no reheat phase." |
Mine takes bloody ages to go out, maybe not as much as 20 seconds but it feels like an age. Even if the engine is hot and has only just been turned off.
I take it that's not right then ![]() |
Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 288 ![]() ![]() ![]() |
Yes, happens when waiting for glow plug light to go out. I have not tried not waiting.
Although yesterday it once started with no delay (the only time for many weeks)! |
miket Member Since: 05 Oct 2012 Location: Peak District Posts: 143 ![]() |
I seem to recall that I had a delay between turning the key and cranking in my 09 110 - eventually the starter gave up the ghost...
