![]() | Home > Puma (Tdci) > Help with Puma injector fault |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 ![]() ![]() ![]() |
Firstly can you get an injector for £70?
Good with resolving - I presume you've had a go with the various injector cleaner additives on the market? |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 ![]() ![]() ![]() |
Danny get your injectors tested mate I took mine to my local independent who tested mine found two faulty ones they was sent away and repaired for 90 pounds
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
As said above, send/take them away for testing.
If you have a local Diesel specialist near you, they will undertake the work. If not have a look online for company's offering this service. I use PowerDrive in Portsmouth quite a bit, they are not local to me but have a good turnaround time. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20629 ![]() ![]() |
£450 each X four.
![]() I use Millers diesel additive which should keep things clean, might this be of some help? |
dannyc85 Member Since: 17 Feb 2016 Location: Middlesbrough Posts: 39 ![]() ![]() ![]() |
How can they charge that much! £70 for a reconditioned one off ebay! Iv found a diesel specialist near me who will test them for me so il go down that route. Cheers for the advice everyone
