![]() | Home > Puma (Tdci) > New Puma advice needed. |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
you can get extra light switches that fit in the switch blanks but are quite expensive as they are genuine landcover parts, or you could go for a raptor pod which fits between the air vent up top and fits carling rocker switches, or you could make your own insert for where your cup holders are to accommodate switches, or mount the switches on the angled wit of the cubby and box them in so not to get damaged.
neil5886 Member Since: 15 Feb 2016 Location: York Posts: 24 ![]() ![]() ![]() |
I've seen the Raptor dash pods, mt concern with them is how easy is it to run the wiring behind the existing dash and into the pod.
I've only had the car a few weeks so trying to keeping it looking factory for as long as possible. |
Plenty have done what you are wanting to do, and posted with photos on here - use the search function and have a trawl...there are plenty of good solutions.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17612 ![]() ![]() ![]() |
I like the two switch unit, that looks neat, where do you get the switches from? Can you get different designs so its easy to tell what each switch does.
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 672 ![]() ![]() ![]() |
Easiest solution is to buy the heated seat switches and some switch blanks to engrave your own symbols. They can be wired to light up with dash lights. I run LED work lights through these without any relays.
Details on here https://www.landyzone.co.uk/land-rover/mak...le.182841/ Apologies for a link to the competition! |
