Home > Td5 > Centrifugal oil filter
leezg
Croatia
Hi guys!
I noticed my oil was over the max line, I was due a oil change anyway, so I dumped the oil, put fresh oil in to see if it will rise again. Now after 600km it did not rise so I believe I am ok. I changed the full flow filter last time.
Since I did not change the oil filters when I dumped the oil, I was wondering if I can change the centrifugal filter without dumping the oil. Is the centrifugal filter housing full or empty when the oil goes to the sump?
Post #505244 16th Feb 2016 6:13pm
miker
It will be empty
Post #505245 16th Feb 2016 6:23pm
leezg
Croatia
Great, so I can leave it for an hour or two and open the filter housing without the fear of oil spilling out.
Thanx!
Post #505247 16th Feb 2016 6:26pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
You can change it up a couple minutes after shut down, no need to wait so long. It can drip out about 50cc of oil, so make sure you have a rag under it when you take it out. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #505372 16th Feb 2016 11:55pm
leezg
Croatia
Great, thanx!!
Post #505380 17th Feb 2016 4:47am
