![]() | Home > Technical > Tow bar wiring |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2532 ![]() ![]() ![]() |
I suppose the first question is do you need 7 pin or 13 pin? When I ordered my 90SW I asked for 13 pin electrics but guess what, it was delivered with 7 pin. The auto electrician at my local dealer was not impressed as he had to convert and it was not as straight forward as he imagined. I'm sure someone on here will know if its a straight plug and play or not. Defender 90XS SW
nmj Member Since: 07 Feb 2016 Location: Hertfordshire Posts: 65 ![]() ![]() ![]() |
i think i will be wanting 13 pin as i think any trailers that i intend to use will be modern with reverse lights etc , unless i am on the wrong track with that train of thought !
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 ![]() ![]() ![]() |
all plug and play - dead simple connection under the rear spray shield in the arch:
http://www.duckworthparts.co.uk/landrover/...rying.html Mike |
many thanks Mike , appreciate your advice , will get onto their website and get it ordered
No problem - its surprisingly simple on all the LR's but the defender is by far the easiest! Mike
that suits me then !! and re mounting the plug , fit it in the recess in the rear cross member rather than underneath join a bracket ? , after looking at various photos of the above it does look neat , rgds
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 ![]() ![]() ![]() |
13 pin needs an extra connection into battery box and on the LR kit picks up a connection off the back off of one of the switches in the dash. Try a search... wiring details have been posted several times. Or track down the LR kit number then go onto Topix for the wiring instructions
![]() edit quick search shows this which is for 110. Will give you an idea of what is generally involved... http://www.defender2.net/forum/topic13747.html? |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
I think you can also buy a converter to 13 pin for when needed, save altering wiring. Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 504 ![]() ![]() ![]() |
The wiring that runs to the battery box and dash, is for the caravan functions - fridge, etc... If you don't need these - then, you can just use the connections in the 9-way connector under the wheelarch. This connector has all of the road lighting, including reversing lights, and a permanent live. . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
excellent , many thanks Guys
Note this is definitely a question and not a statement... will it cause a problem at MOT if not all pins are correctly wired and functioning?
I though I had read that now 13pin sockets are part of MOT? |
I seem to recall that the MOT Test was updated in 2012 to include towing electrics. Here is a quick quote from an item in a caravan magazine-
There will be a basic security/damage check of 7-pin sockets, but 13-pin sockets will be subject to a full electrical connectivity check and incorrectly connected or inoperative circuits will result in MOT failure. Best to check with your local MOT Station or VOSA Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6635 ![]() ![]() ![]() |
The branch which goes forward to the battery box is for the ignition switched feed for 13 pin electrics. This branch is still not fitted on my XS
![]() Quite why LR didnt provide the required ignition supply at the back as part of the other tow electric connector I don't know ![]() ![]() ![]() |
I understood if you fitted the 13pin to 7 pin converter they dont test it because they have to test the car as presented and 7 pins do not get checked.
![]() Fortunately i dont have MOT's Mike |
