Home > Technical > Oil code on scanguage? what does it mean. |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3773 |
Hello
I have this message on the gauge, looked up on http://www.datsc.com/tabid/122/OBD-Error-C...fault.aspx however I don't think its an error as such? do I just need some oil? No other lights on and drives as normal. I guess without the code reader I would be none the wiser at this point but I would like to know what it is. Click image to enlarge Thanks |
11th Feb 2016 7:36pm |
It's a user settable alarm in the Ultraguage (it's not a Scangauge, that's something different).
It is there to remind you to change the oil after however many miles, you can set it to whatever you like or disable it. Nothing to do with the Defender. |
11th Feb 2016 9:00pm |
Many thanks
sorry I got the unit name wrong I looked at both back when I bought this but liked this as its smaller. I will have a look at the settings and change them Thanks |
11th Feb 2016 9:10pm |
