![]() | Home > In Car Electronics > Grey plug under cubby |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6642 ![]() ![]() ![]() |
What colours are the wires?
RustyM Member Since: 28 Oct 2013 Location: Africa/The Med Posts: 222 ![]() ![]() ![]() |
Yes it is the factory fit sub connector, not in the same country as my Defender so unable to help with the other end.
Someone else should be there to. 90 & Wolf 110 XS Previously owned SI SII SIIa SIII & Light weight (air portable) |
JDH Member Since: 20 May 2015 Location: Horsham Posts: 61 ![]() ![]() ![]() |
Hi Martin,
As far as I can see in my picture as new cubby is in now I have the following 1 Black wire 1 Purple wire 1 Blue wire 1 White & Black wire 1 Red & Black wire 1 Pinkish & Black wire (Pinkish is a colour, honest!!) |
Ok lovely, thanks RustyM! I will keep digging haha
Sorry I didn't see the second photo of wire colours.
Yes it's the sub connector you lucky ![]() ![]() I can't ID the connector, PaulMc is better at these ![]() ![]() ![]() |
No problem, I usually have trouble uploading photos off my iMac so I guessed it hadn't uploaded the photos properly!
Is said sub plug quite a rarity then hence the lucky part? ![]() Could be a handy find then seeing as my next move was to improve the audio in some way, hopefully someone might come along with a link to the sub! Thanks for the help Martin ![]() |
1978 Member Since: 04 Aug 2015 Location: Lancashire Posts: 519 ![]() ![]() ![]() |
Someone is selling a factory sub and head unit/speakers in the for sale section, perhaps this is the one you need?
http://www.defender2.net/forum/topic43798.html |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
OOh I wonder if I've got one under there?!?! MY2012 110 XS SW?
Anyone know what amps are standard plug and play compatible with this plug? ![]() |
1978 Thanks for the link, i think thats being sold as a package and I've recently fitted a bluetooth sony head unit into my 90 along with the iso adapter from mud stuff to make it work.. hopefully changing that iso adapter to make it compatible with my sony head unit won't have affected the plug in question and stopped it working or whatever.
JOW240725 I was guessing that this plug was just for an active sub to plug into so I'm not sure, beauty of an active sub is every thing can be nice and tidy in one place obviously and you don't have to worry about where to put the amp, the sub all the wiring and so on so I'm keen to find the exact plug and play one, although I'm guessing even with the sub that is plug and play for this connector you'd still have to run the RCA cables from the sub to the rear of the head unit. i could be wrong though ![]() ![]() |
That's interesting!
Although the factory fitted subs do seem to take up quite a bit of space in the rear passenger footwell - are there alternatives? |
The SVX sub and amp is different to the later Alpine units.
My 2015MY 90 XS does not have the connector spare. I've just been out to double check and I have an empty hole in the rubber matting and a blanking sticker over the hole in the metal plate. ![]() At a guess I think that the connector series is Yazaki "YES" The connector in your pics is 7282-5560-40 and the matching one you'd need to make a loom is 7283-5560-40 I can't find a supplier though ![]() There are various link looms that LR list, but none appear to be a match for what you'd need to plug into the sub connector: LR040845 LR040846 LR040847 ![]() ![]() |
Cheers Martin, I spoke to a local landcover dealership and they basically said they have no idea what the plug does where i can find the alpine sub to plug into it and so on just generally didn't know anything about it!
If it was fitted by land rover i struggle to see how they don't know anything about it and how it is so hard to find the alpine sub with a female version of this connector! ![]() Oh well, shall see if any other members could shed a little more light on the subject. Once again thanks all ![]() |
You need to go into the parts department and get them to look at the parts list for the subwoofer.
I wouldn't expect the sales or service departments to know anything about retrofits. Or have a nose about at http://new.lrcat.com/#!/1235/2632/3061/238 ![]() ![]() |
Is LR008912 the older subwoofer?
More info here: http://www.defender2.net/forum/topic31425.html ![]() Last edited by Supacat on 13th Feb 2016 12:14pm. Edited 1 time in total |
