Home > Puma (Tdci) > Battery Isolation Switch |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
I have changed your username to garry.hingley to cut down on spam you'd receive to your email address
Welcome to the site 1988 90 Td5 NAS soft top 2015 D90 XS SW |
8th Feb 2016 11:56am |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
Hi garry looks like i have posted a similar request to you except for a 2.2 Puma..some subjects get little response im afraid(unles you have had loads of pms on the subject of which i have had zero)I was planning to use this box from here: http://www.fcx.co.uk/#!product/prd1/262124...off-switch but i dont know if it comes with wiring instructions! but i was going to use this as a switch cut of switch: http://www.ebay.co.uk/itm/Caterpillar-Batt...SwpdpVeoEE As for the hydraulic lock i dont think its legal for the clutch as it is deffo illegal for the brakes have one fitted!Anyway good luck ! |
9th Feb 2016 9:23pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10381 |
Welcome.
I have the FCX kit fitted. Click image to enlarge Click image to enlarge |
9th Feb 2016 9:39pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17382 |
You'll need to figure out how to deal with the alarm and BBUS with battery disconnection.
It is entirely legal to fit an hydraulic lock to the clutch, no problems at all with this. The name Mechlock comes to mind (Google with different similar spellings if need be). It is believed to be illegal to fit to the brake lines because of the risk of the vehicle becoming immobilised in a dangerous place, e.g., the middle of a level crossing. |
9th Feb 2016 9:40pm |
Mike_B Member Since: 23 Jan 2011 Location: Moray Posts: 550 |
Was it X eng or Mud UK selling this item for a while? Few hundred quid though I think
9th Feb 2016 11:13pm |
Hi blackwolf how does the clutch work? do you lock it so the clutch cannot be depressed or do you depress the clutch then lock it ...will this effect the cluch mechanism over time? as we all know how good a puma clutch is! |
10th Feb 2016 12:40am |
The hydraulic locks are in effect lockable one way valves, i.e., when unlocked fluid can flow either way, when locked fluid flows one way only.
On the clutch you'd fit the device so that when locked the clutch pedal can be depressed to throw the clutch out, but the clutch will then stay out, so no drive. It doesn't stop someone towing the vehicle away, of course, or simply cutting the hydraulic line between the slave cylinder and the lock and driving without using the clutch. If fitted to a brake line, the device would allow the brakes to be applied but then they wouldn't release, effectively immobilising the vehicle. Again, releasing the fluid would release the brakes, but the vehicle would essentially become undrivable with no brakes. It could still be towed away. In either scenario the real defence is that the villains would probably not know of the device before finding out that the vehicle was not drivable, and would therefore not have come prepared to tow or disable the device. The legality of fitting a device to the brake line is interesting, since I have never been able to establish why everyone thinks it is illegal and have never found any specific legislation making it so. I think that the case may actually be that a device so fitted would be unable to gain type approval, and therefore no manufacturer sanctions this. (If anyone knows specifically what legislation if any actually makes it illegal, please say). The 'dangers' are pretty apparent, namely that the vehicle becomes immobilised in lane 3 of a busy motorway, half-way across a level-crossing in front of a train, etc. Realistically this is very unlikely, since if the vehicle is stolen it will probably end up being abandoned immobilied at the first junction or hill, i.e., in a predictable place. I would have no hesitation personally in fitting a device to a brake line. Back in the 1980s my father had a Granada which was fitted with a lock on the brake line by the supplying main dealer, with no issues. This device impressed me so much that when I rebuilt my S1 86" in the 90s, I fitted a lock on the brake circuit since it is really the only effective security on a ragtop. It is actually very useful in other ways, for example you can apply all four wheel brakes and get out of the vehicle when winching. |
10th Feb 2016 9:24am |
This is the device I mentioned in my earlier post: Meck Lock.
It isn't the same make was the one I used (which is no longer available) but the principle is the same. I'm not sure where you'd buy one now, MUD used to sell them but no longer seem to. |
10th Feb 2016 9:27am |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
This is off topic from the original question Battery Isolation Switch
But I too have been looking at the Mech Lock and have the installation instructions in pdf form, for the TD5, 200 & 300tdi Defenders. Just trying to establish what is known for the Puma >2007 2.4 / 2.2tdci, I can see it will be similar. Anyone Interested PM me with your e-mail address and I'll send you the pdf. http://www.mlsystem.co.uk/security/ SKIP https://www.defender2.net/forum/topic83242.html Last edited by X4SKP on 10th Feb 2016 11:50am. Edited 1 time in total |
10th Feb 2016 11:14am |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5110 |
Do not bother with the plastic keyed isolators versions as they are as effective as a chocolate teapot for security because plastic keys are all the same, buy,one and it will fit thousands of others. Instead go for a proper security keyed version and a metal box mounted under the vehicle that the battery cables run into otherwise with any isolator a thief will just cut and re-join the wires bypassing the switch. I have this set up with a 15 amp fuse linking the positive so that I retain power for codes and alarm but obviously 15 amp will blow if the vehicle is started with the isolator keyed in the off position. I am sure if you do a search you may find this isolator cheaper than the one for sale from vehicle wiring products.
http://www.vehicle-wiring-products.eu/prod...tor-switch For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
10th Feb 2016 11:27am |
garry.hingley Member Since: 05 Feb 2016 Location: Leeds Posts: 4 |
Thanks for all the feedback Guy's, some interesting comments.
I dont have a wiring diagram for the 2.4 Puma but I had assumed that if I put an isolation switch on the main positive cable from the battery to the starter this would not effect the supply to the alarm / BBUS. Is this not the case? If anybody has a wiring diagram I would be most greatful. I like the look of Gilarion's isolation switch, I might opt for one of these. As for the Hydraulic Clutch lock, I found the Mech Lock product a while ago but thought it was a bit pricey for a valve and a bit of brake pipe. I can pick the same components up on ebay at a fraction of the cost. I was going to fit a simple on / off valve and padlock it shut when I park up. Dont see the point of a one way valve. |
10th Feb 2016 1:44pm |
hi blaxckwolf just been searching for security ideas ..where would be the best place to put the brake lock ona puma.........please pm me if you dont want to advertise !thanks in advance! |
29th Jun 2016 10:08pm |
Tomcat 106 Member Since: 08 Jun 2015 Location: Essex, just. Posts: 124 |
I use one of these on my Comp Safari car. A very neat solution. The on off function is by two small push button switches which you could conceal anywhere. It has proven 100% reliable over 12 years of racing... Before that the standard "plastic key" type started to give problems due to dirt ingress and poor quality electrical contacts.
It is not cheap.....but neither is a replacement Defner!! MY15.5 110XS CSW 1956 88" S1 2004 Tomcat 106 Comp safari |
30th Jun 2016 6:18pm |
Thanks Tomcat 106 I can see that for a competition vehicle this is ideal, as it isolates all electrical systems in the event of an incident. It states that it should not be fitted to a road going vehicle, and that it draws 1amp whist on so would drain the battery if isolation is maintained without charging.
My 'search' is to understand what options are available to electrically isolate a Puma Defender whilst maintaining all alarm (and possibly other systems). I can tackle just the Starter Motor and have a security switch capable of handling 500amps for 5 seconds that could be used. I'm looking at maybe isolating the Solenoid to the Starter as an alternative. So my question to the forum is has anyone actually done this?...aiming for, or achieving a similar outcome. Thanks again for your reply... SKIP https://www.defender2.net/forum/topic83242.html |
1st Jul 2016 8:05am |
