Home > Maintenance & Modifications > Installing a heated windscreen
Gleaney
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Morning all. My wife's defender has a leak around the windscreen (surprise !) so while it's coming out to be sealed we we're thinking of putting a heated one in to replace it. Can anyone from experience tell me if this is a big expensive job regarding buying the screen and wiring etc.
Cheers. Damn planet is short of Kryptonite !
Post #501983 8th Feb 2016 7:27am
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
The windscreen can be had for around 150£ while the loom from e.g. MobileCentre (site sponsor) is about 100£.
Checked it some time ago and I don't know exact numbers anymore but it is around this figure.
All in all a very welcome upgrade, all the Defenders here are fitted with one, wouldn't want to be without, esp. on the Td5 it is a very useful upgrade when the weather is damp. Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #501988 8th Feb 2016 7:35am
Gleaney
Thanks Peter. I have one in my Defender and it is very worth while. Thanks for the reply. Damn planet is short of Kryptonite !
Post #501993 8th Feb 2016 7:41am
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
One of the best value upgrades you can get!
I upgraded when my screen started to leak, around £150 + new seal and labour to get the screen fitted, I did the wiring my self with my own loom which probably saved at least another £50-£100.
Worth every penny Thumbs Up
Post #502020 8th Feb 2016 9:14am
Gleaney
Can anyone tell me if the wiring loom is there? It's a 61 plate. Damn planet is short of Kryptonite !
Post #502060 8th Feb 2016 10:55am
Martin
Site Admin
No the loom is not in place unless your 90 has a heated screen from the factory.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #502070 8th Feb 2016 11:36am
Martin
Site Admin
However if it's the one you have set in your profile, then it's a XS and should have a heated screen Confused  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #502071 8th Feb 2016 11:37am
Gleaney
No. It currently has a non heated windscreen from factory fitted Damn planet is short of Kryptonite !
Post #502100 8th Feb 2016 12:50pm
Martin
Site Admin
Is it an XS?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #502111 8th Feb 2016 1:13pm
Retroanaconda
Heated screen is only there with the winter pack (along with heated seats) is it not?
Post #502116 8th Feb 2016 1:22pm
Martin
Site Admin
XS has winter pack as standard (certainly in the UK)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #502120 8th Feb 2016 1:25pm
Gleaney
Is the heated windscreen bought as a pack with the screen, wiring and switch? Damn planet is short of Kryptonite !
Post #502182 8th Feb 2016 3:53pm
Martin
Site Admin
An XS specification Defender normally has the following as standard, which is called the "Winter Pack" by Land Rover in the brochure:
Heated Windscreen
Heated Seats
So all the wiring and switches would be in place for those.
This pack is (was) an option on other specifications.
Any Defender that was not factory fitted with a heated windscreen will NOT have the wiring in place.
OK for the pedants I'm sure there are a handful of exceptions to this where the line ran out of standard looms or whatever Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #502188 8th Feb 2016 4:03pm
Martin
Site Admin
Sorry for the confusion, I'm talking about the factory-fitted option.
For fitting after that, you can either buy the whole lot from one place, or the screen from someone and the loom from elsewhere, etc.
I'm just a bit confused why you appear to have an XS without a heated screen.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #502191 8th Feb 2016 4:08pm
Gleaney
Thanks Martin. The heated windscreen is going into one which does not have the loom installed. So what I'm wanting to do is purchase the heated screen,switch gear and wiring kit to put one in.
Do you know where this could be bought? Damn planet is short of Kryptonite !
Post #502195 8th Feb 2016 4:16pm
