Home > Tdi > quick one about fitting drop arm 300tdi
jonnytatt
United Kingdom 1988 Defender 90 300 Tdi SW Nato Green
Tomorrow when i come to fit a new drop arm on a spare 4 bolt steering box i have lay around is there a specific way to fit the drop arm so its central to the gearing inside.
I read there is only one way the drop arm can go on the steering box splines but then i read there are 4 odd splines so make sure ones to the front.. .i Would like to just double check because if anyone can get it wrong i will.
Thanks
Post #501879 7th Feb 2016 9:05pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Wind the box fully to the left, then count to full lock right, once you have this half it and turn that amount left. Confirm its correct by then counting left again to the lock, once happy count from left lock back to the centre.
Has always worked for me, just a quick note ensure it is a r/h drop arm for a r/h box or vis-versa if the wrong arm is fitted you will have no end of problems. I had one bloke at work replace the entire steering system including the 2 boxes (using the same arm) before he asked for help as it still wasn't working Rolling Eyes 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #501896 7th Feb 2016 9:28pm
jonnytatt
Thanks Mash . Yes it is a RH drop arm and box.
So turn the splined shaft all the way left..
Then all the way right counting the turns ( best marking it)
Halfing the turns then back to the left and pop on the drop arm with the slots alighned.
Post #501900 7th Feb 2016 9:39pm
Mash
Yep Thumbs Up
I always double and triple check once fitted to ensure its ok, oh one other point make sure the tab washer is correctly locked off and the nut is torqued properly have seen too many with no nut and the drop arm ready to fall off. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #501909 7th Feb 2016 10:00pm
jonnytatt
I Will do Sir thanks for your help!
Post #501912 7th Feb 2016 10:03pm
