![]() | Home > Td5 > Strange Central Locking Issue !! |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 ![]() ![]() |
Nice work Chris.
Done anything more with the tub cover? |
christyler Member Since: 10 Dec 2010 Location: Cork, Ireland Posts: 67 ![]() |
Not yet, its impossable to work here at the moment, snow, rain, dark every time you go to do anything. i am working outside so it dosent help. I have done some measuring and cutting of alluminum so should be able to get the lid/frame in this week end, if it dosent rain. |
Good stuff
Vixen Member Since: 16 Mar 2010 Location: NSW, Orstraya Posts: 97 ![]() ![]() |
I found with my 2006 td5 that I had to be within a metre of the thing for the central locking to work, and sometimes it would not work unless you were even closer.
Apparently the aerial (?) in the bodywork is not very long......Land Rover made it longer and no further issues. Apparently her in Aus at least, this has been a bit of a problem. Anyone else found this? |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
If you find the wire you can extend it into the roof and this solves the problem. The wire is the short one, i think orange and white but dont quote me on that (there is only one short wire however), on the alarm ECU, which for security reasons im not posting the location on a open forum but if you PM me i will tell you where it is. With new batterys in my fob i can lock and unlock at 25 metres, before i had to be in touching distance of the door. Pete. |
Its easy to spot the antenna wire, Its the one not connected to anything
